Originally Posted by AJrollin
(Post 13885851)
Ok Randy sounds good, also just needed some clarification as to whether I needed the new 2.0 hotwire interface or if I can use the old hotwire interface for updating my RSX? Thanks
ok thank you
Ok so I still have the issue where the advanced block and the default setting block will not allow me to click on it. I have uninstalled and reinstalled at least five times. When I click on help to see what version the Hotwire is, it says 10.4.2. I thought it was supposed to be 10.2 ?? I have windows 7 and I also have the hotwire app on my Galaxy S3...can the RSX be updated on the hotwire app? Thanks for any help.
Well I decided to dig out my old laptop with widows XP on it and Hotwire installed correctly with 10.2 and everything works as it should with my RSX now. So, there is something going on with Wndows 7.
I just ordered one of these and will have it next week. I really like the RX8 programming setup, and hope this is similar with the hot wire? I also have a HV servo, so the 7.4 will really help with my Savox 2271 servo, on a Dex410.
(Post 13886418)
Originally Posted by platgof
(Post 13886669)
(Post 13886084)
You need to go in and delete an old "Hidden" file that the OS likes to hang onto. This is no longer an issue once you've removed it from here on out. There's a how to video on our Youtube page "Vista how to" that lines it out, same steps but simply looks a tick different. Same idea. You'll be set after that. |
(Post 13886669)
Thanks, I will have my sometime next week, awesome! Now I can use my RS Pro for another car. That RS Pro is very powerful.
So radio calibrating says to put epa and dual rates to 100%..... Why not 150?
What would be the benefit of doing 150%?
Just wanted to mention how awesome the tekin support was at motorama a few weeks ago. They really helped me out with my rsx and gen 2 motor. Customer for life! |
You can do 150,it's just more resolution. We generally recommend 100% that way when you talk to someone you can say "I have my brakes at 80%" for example.
A buddy of mine is letting me try his speed passion 7.5R motor, before I hook it up to my RSX, I wanted to know if it would work okay with it? Also, anyone know when the new update to fix the clicking noise will be out? Thanks
(Post 13898249)
| All times are GMT -7. It is currently 04:01 PM. |
