Like Tree95Likes
Tekin RSX Thread
Old 10-23-2013 | 01:08 PM
  #136
Randy_Pike's Avatar
Team Tekin
Originally Posted by ArmySSG
This ESC Looks sick.. to be honest looks alone kills the RX8 GEN2 IMO.. It's great that Tekin makes products where the only thing that you can complain about or debate is looks! With that being said.. any cool guy cases for the RX8 Gen2 coming out lol!
We do offer optional black cases for the RS Gen2, RS Spec and Rx8 Gen2
Randy_Pike is offline
Old 11-04-2013 | 07:57 AM
  #137
boudin4evr's Avatar
It's official!
https://www.facebook.com/photo.php?f...type=1&theater
boudin4evr is offline
Old 11-04-2013 | 08:22 AM
  #138
Wildcat1971's Avatar
What is the ship date?
Wildcat1971 is offline
Old 11-04-2013 | 11:04 AM
  #139
BRSracing's Avatar
I know the obvious difference between the RS Gen2 and RSX is the motor size you can use with them.... But aside from that is there any other advantage the RSX offers over the RS? Such as smoothness settings etc?
BRSracing is offline
Old 11-04-2013 | 11:14 AM
  #140
Randy_Pike's Avatar
Team Tekin
If you were to run a RS Gen2 and RSX back to back with say a 10.5, setting for setting, no you wouldn't notice.
Old 11-04-2013 | 11:21 AM
  #141
lbenton's Avatar
Originally Posted by Randy_Pike
The Pro2 will work on the RSX. They critical factor will be the model/car weight. Keeping in line with the 4lb car limit an RSX and Pro2 in a 2wd will work just fine.
The team is all running the RSX this week at worlds. Any ETA info will be shared after the event is over. What you see in all the media coverage is production unit save for some fan shroud parts.
I'll share some data logs of their performance once I get the thumbs up from the boss if some of you are interested to see where Lutz, JR Mitch and the rest of the team is running temp wise. FYI, both of those guys are using 5.5's in 4wd mod buggy.
As always team drivers will get this equipment before public release so if you have a team driver check out his/her car as most will be getting them shortly after Worlds.
Would like to get more info on the use of 4 poles with the RSX. I would be inclined to use this in both a 22SCT and the upcoming HB D413, so the weight should not be an issue. But there must still be a limit.
If I were to use a 4 Pole SC 540 motor at 7200 KV in either of those vehicles would I be asking for trouble, or would that be just fine?
I currently run a Pro2 5800 in my 22SCT, but I do have a 7200 KV Quad 4XS in the toolbox with a 1/8" output shaft.
I want to be able to have fun and see the limits of things without letting any smoke out.
lbenton is offline
Old 11-04-2013 | 01:17 PM
  #142
WIGMAN's Avatar
It is my understanding that the 7200KV motor you are talking about was designed to be run in oval with a 1cell lipo, have you tried running it on 2 cell yet?
WIGMAN is offline
Old 11-04-2013 | 02:02 PM
  #143
lbenton's Avatar
It is a 4WD short course motor, and will do fine on a 2S setup as long as you do not get wild with the gearing. I can not see this being the motor for anything very heavy or to run any place with less than a lot of space. I also would really think this would be beyond the draw anything Tekin has to offer short of the RX8. It would be a lot of fun in a 4 wheel buggy though...
lbenton is offline
Old 11-04-2013 | 02:03 PM
  #144
they said no to 4 pole motors. rx8 is for 4 pole motors. that being said, I have seen a few guys run a tekin 4 pole and rx8 in the b44.2 buggy.
Old 11-04-2013 | 02:34 PM
  #145
Waflet's Avatar
The Pro2 will work on the RSX. They critical factor will be the model/car weight. Keeping in line with the 4lb car limit an RSX and Pro2 in a 2wd will work just fine...
Hideeho
Tekin is usually very reserved on what they say their ESC's are capable of. If one of the tekin guys comes on & says it will work, to me, that means they tested & abused that combo as much as they could & did break it. If they don't say it works, I take it they have not tested the crap out of that combo. I also think we will eventually see people running (whether tekin says it works or not) 4 pole motors in wheelers sooner rather than later. Although, why you would need more torque in one of these mini-monsters is beyond me.
Waflet is offline
Old 11-04-2013 | 02:38 PM
  #146
they are stupid fast with a 6.5. So yeah, why get more? the guy with the 4 pole and rx8 in the b44 was doing oval.....
Old 11-04-2013 | 02:45 PM
  #147
Waflet's Avatar
Hideeho
Will you have an optional white case for the RSX?
Waflet is offline
Old 11-04-2013 | 03:47 PM
  #148
Randy_Pike's Avatar
Team Tekin
Sorry but no. You can't get a white anodizing
Old 11-07-2013 | 07:56 AM
  #149
hello, I am using the RS pro now and like the fact that I can use the binding posts and put a small fan there, i run either a 17.5 or mod 10.5 and with a fan there the temps are very good. for this RSX, is it the same? I mean, if I don't use the fan on the top but rather put the fan blowing to the binding posts would it give same effect to cool the esc like the RS pro? i was hoping to put the cap on the top of this RSX esc as i am doing for my RS pro.
is the alu heat sink removable? and can i just cool the esc with a fan blowing to the binding posts?
thanks
rshair is offline
Old 11-07-2013 | 08:08 AM
  #150
20 SMOKE's Avatar
If your only running down to a 10.5 the rs gen 2 is all you need as it has a 8.5 limit.
20 SMOKE is offline
