Protek 130T Issues
I have a problem that i cant figure out. I've went as far as i could with my troubleshooting. anytime, while my engine is running, and i hit the throttle, my servo steers hard right past my set endpoints. has anyone had this issue with the protek servo's, or any other servos for that matter? and if so, how did you correct this problem. by the way, when the engine is off this does not happen it seems that the vibration is what is making the steering servo freak out.
set up:
Mugen MBX 6R
Futaba 3PL
RB Blast V12
Savox 1267 (Throttle)
Protek 130T (Steering)
set up:
Mugen MBX 6R
Futaba 3PL
RB Blast V12
If you have an extra servo laying around, plug it in and see if that 1 does the same thing. It might be a problem in your receiver. Or switch your throttle and steering servo's for test purposes....
If you Auvergne any problems that you believe to be related to our products please contact customer service and they will take care of the return for you. We back our products 100% and will get you taken care of.
