Proper Steps for Charging Lipo? >
Old 05-30-2013 | 08:44 AM
Default Proper Steps for Charging Lipo?
Hi. I am currently using a Hyperion 0720i net3 AD charger and using AC power to charge my batteries however I was told it would be better to use a DC power supply. I agree with this as my 1st hyperion net3 AD charger died after only a month of usage. I have decided to get a DC power supply and use DC power instead for my newly replaced charger.
The question is...what are the proper steps for connecting the power supply to the charger? Do I switch on the power supply before plugging the charger to it? Or do I connect everything 1st and then switch on the power switch? i heard about someone who blew his charger due to a power surge when he switched on his power supply which was already connected to the charger. It would be great if someone could help me with this. Thanks in advance!!
saternal is offline
Old 05-30-2013 | 04:29 PM
I turn on my ps which is plugged into a 40A fuse block, then plug the charger into that. Then when im done, I just reverse the procedure.
Johnnysplits is offline
