LRP FLOW funny behavior >
Old 05-17-2013 | 12:53 PM
Default LRP FLOW funny behavior
I have an LRP Flow speedo that I just received, after plugging it in and getting it all wired up, I turned it on to do the initial set up and set the speed control. Once the first set up was done, I tested it out and it worked great. I then shut it off and turned it back on, when I did, it rev'd the motor up for about a half second then went to the neutral setting. I shut it off and turned it on and it did this again. The controller seems to work perfectly once it goes back to neutral, but when I first turn it on it wants to rev the motor.
does anyone know why this is happening or what I might change?
Racerbucky is offline
Old 05-17-2013 | 03:17 PM
JayL's Avatar
R/C Tech Elite Member
did you calibrate the esc to the radio?
What brand/model radio?
Some radio's have a very narrow deadband and the esc thinks they have some throttle when they are just centered
JayL is offline
