Define "hold" on new as3x receiver >
Old 05-17-2013 | 07:26 AM
07d675cm2's Avatar
Default Define "hold" on new as3x receiver
Got a question I'm looking at these new as3x receivers for airplanes and noticed in the online manual that this receiver keeps track of the number of "holds" that happend in a flight. The receiver is the SPMAR635 in the instructions it explains that it keeps track of them but doesn't explain what they are. Can someone shed a little light on this for me? If I had to guess I'm wondering if its how many times your radio and receiver lost connection for a split moment during the flight but again I'm just guessing. Thanks.
07d675cm2 is offline
Old 05-21-2013 | 07:48 AM
A- Antenna fades on receiver A
B - Antenna fades on receiver B
L - Antenna fades on the left receiver
R - Antenna fades on the right receiver
F - Frame loss
H - Holds
An antenna fade represents a loss of a bit of information on that specific antenna. Typically, it’s normal to have as many as 50 to 100 antenna fades during a flight.
A frame loss represents simultaneous antenna fades on all attached receivers. If the RF link is performing optimally, frame losses per flight should be less than 20.
A hold occurs when 45 consecutive frame losses occur. This takes about one second. If a hold occurs during flight, it’s important to re-evaluate the system, move the antenna to a different location and/or check to make sure the transmitter and receivesr are all working correctly.
vlad_vy is offline
Old 05-22-2013 | 10:56 AM
07d675cm2's Avatar
Very nice description thanks so much.
