TORO TS 120A ESC
#811
Regional Moderator
Before I talk to SkyRC, I thought I'll post a video of my "problem" and see if this is in fact normal.
My car coasts nicely when the ESC is set to blinky or when Im in partial throttle. But when it goes into boost/turbo/full throttle, the car will grab a handful of brake when I release the throttle. Not sure if this is normal or not.I have the ESC set to no drag brakes and I release the throttle softly so that it doesnt bounce into the braking zone.
https://www.youtube.com/watch?v=haUTMe_5c5U
#812
Has anybody ever had their Toro making their car run backwards? I've just witnessed it again today with mine.
My previous 160 did, shortly before it went up in smoke. It was replaced under warranty by Schumacher (I'm in the UK) and 2nd time out today, my new one did it again.
It was perfectly fine for 4 qualifiers but then in the final. My car was on the track, I blipped the throttle and the car moved backwards. I tried it a few more times and each time the car moved backwards.
One of my racing buddies turned the ESC off, then back on again and now it was was fine again. No problems for the rest of the race.
I was using a brand new Reedy 13.5 turn motor (2nd meeting) same for the sensor cable.
Anybody else had the same issue? I'm just worried it's going to go up in smoke again, like my previous one did.
CE
CE
#813
I spoke with someone and they said it also went reverse before the start of the race..
So far I've noticed these things
-car stops for two seconds from a mild hit
-random reversing
-personally my car sometimes jitters forwards in neutral. I doubt it's my radio, using an Mt4. I will update firmware and monitor it. Also using brand new sensor cable. Possibly that, not sure
-also at very low rpm it's not the smoothest, once again jitters.
-random reversing
#814
Regional Moderator
#815
-random reversing
-random reversing
#816
Your first sentence didn't make sense to me. Are you saying any changes I make can change the motor direction? Btw, I never had the reverse issue but someone I know did.
What I'm concerned is the jitter problem. Never had it with any esc except this toro esc.
#817
YES All my friends that are using the WiFi or Bluetooth have this issue and they just make sure before they save there changes they check motor direction.
#818
i have hed good luck with my wifi, the only issue i had was the very first time i used it my throttle curve changed but only that one time but I do what Rick said I just make sure i look at everything before i save,
#819
my new TS 150 and new motor come in today I cant wait to get it mounted and hit the track this weekend
#820
Could try lowering it. Also check your Boost controlled by throttle setting, try turning that off if its not already.
#821
#822
#824
#825
After setting running mode to forward/brake/reverse it always changes back to forward/reverse by its own. Updated both program box and esc to latest version. Anyone experienced this and any solution? Thanks!
