TORO TS 120A ESC
Anyone using this ESC? I've been searching for reviews on RCTech and the net but have found nothing. This ESC looks promising with the all the features and price under $100 USD.
Constant/Burst Current: 120A/760A
Motor Compatible: Brushless Sensor & Sensorless ESC
Car Compatible: 1/10 and 1/12 Buggy and Truck 1/10 and 1/8 Crawlers
Motor Limits: 5-6S NIMH or 2S LIPO--≥3.5T(1/10 Buggy), ≥5.5T(1/10 Truck) 8-9S NIMH or 3S LIPO--≥5.5T(1/10 Buggy),≥8.5T(1/10 Truck)
Resistance: 0.0003ohm
Battery Cell Count: 4-9S NIMH or 2-3S LIPO
BEC Output: [email protected], line
Weight: 45g (w/o wire)
FAN: [email protected] , MAX 12.6V
Thank you WindDrake.
http://www.falconsekido.com/products...-brushless-esc
the difference - hobbywing gives you the solder posts and this toro one don't
remember back in the day of brushed motors and Tamiya's Voltac speedo??? that was a 100% re-branded KO speedo - but completely done in Tamiya blue and Tamiya stickering
so it happens a lot
Is there any source that proofes that it is a Hobbywing?
The size is very different and the Toro doesnt have the alloy case.
Even if its made by HW which is very possible its obvious not the same speedo.
Looks a lot like this guy
http://www.hobbyking.com/hobbyking/s...grammable.html
And this guy
http://www.hobbyking.com/hobbyking/s...ogram_Box.html
Unfortunately seems to be a rebranded Hobbyking. Sounds a lot like hobbywing
And this guy
I have this esc and run it with a novak 4.5t 550. Seems fine. Has the ability to adjust throttle and brake curves via PC.
I'd say it's a safe bet both the Toro and the Turnigy are made by Hobbywing, as Hobbywing make gear for a few other brands, it would likely be damn near the same internals, with a cheaper spec plastic case, software looks less tarted up, but functions are the same in every way.
A week or so back, I had a strong urge to buy the Toro, only problem is the almost pointless nature of blinky modes on brands/models that may never get submitted to ROAR for approval, making one of the biggest selling points of an ESC that will do Mod/Boost stock/Blinky all in one is negated by it not being legal in blinky.
So, viscous technology makes them.
I run the toro sc120 with a 4000kv 550 in my scte and the only thing i would want more would be the ability to run sensored. I got mine as a combo with a 4600kv for $103 shipped from japan to my door. it comes with a programming card but usb/pc programming would be nice too.
All told i'm very happy with the combo. just wish i had gotten it with the 4000kv instead of the 4600kv, since we've moved indoors to a virgin clay track that is smaller then the outdoor track which has closed, I had problems keeping the motor cooler. It was running at 150-160 after 6 min. the 4000kv comes of at 130-135 after 6 min.
I run my toro ts120 with a novak 4.5t 550 with sensor wire and its performs well.
