Like Tree34Likes
TORO TS 120A ESC
Old 11-21-2015, 09:44 AM
  #766
tonylunatic's Avatar
Trader Rating: 45 (100%+)
Originally Posted by bring it on
Correct. Skyrc is still waiting on the plastic one to be roar approved. . As far as what is different? Nothing except the case
Thanks for the reply, I wanted to make sure before I bought one. But the plastic case one IS ROAR Approved, according to the list on their site. Model#300044-01
They look promising, any issues with then?
tonylunatic is offline
Old 11-21-2015, 10:40 AM
  #767
no, I run them myself
bring it on is offline
Old 11-21-2015, 10:41 AM
  #768
USA Team Driver Jacob getting it done again last night lapping almost the hole field... He is running a Toro TS120 and Ares Pro Motor
Old 11-23-2015, 03:23 AM
  #769
I myself don't like the sc120. Also the Ts120 is designed for 540 1-10th 2 pole motors and I wouldn't recommend running it with a 550 4 pole motor IMO
So what ESC pick for the SkyRC TORO S-Pro4 motor ?
Technical specifications of "Toro SC120A SK-300052-01" and "TS120A Aluminum case SK-300062" are identical, but Skyrc recommends "Toro SC120A SK-300052-01" for TORO S-Pro4 brushless, why ?
karam is offline
Old 11-23-2015, 07:37 AM
  #770
I myself would run the ts150
Old 11-24-2015, 08:56 AM
  #771
Dino_D's Avatar
The TS-120 was designed for 2-pole motors. It is compatible to SOME 4-poles, but not all.
The SC-120 works with all 4-poles.
The TS-150 works with all 4-poles but is a slightly bigger ESC
Dino_D is offline
Old 11-29-2015, 03:16 PM
  #772
guys, i thought id just jump in hereand let you know what im finding with my SkyRC SC120 esc's....
I am doing 2 RC10GT brushless conversions, one for me and one for my son. Well I ordered two SkyRC SC120A ESC's and the wifi module. Well, as it turns out, one of the SC120A ESC's is faulty, s it does not turn on, or do anything at all. DOA.
I just wired them up today, and as the DOA one surprised me, I tossed it back into the box and proceeded to wire the next one up, its OK. And functions just fine.
Next, I set up the wifi programmer with my Galaxy Note3, and sure enough, the Note3 see' the WiFi programmer and is able to connect to it. I then fire up the App ESC Link. and thats pretty much where it stops. The app is failing to see the ESC, so I try again, and then it does, but after a few moments it errors out....great, thats a no go. So I try it on my Sons IPod, same s%$t.... Doesnt work. I also tryd the other App,SkyRC Link. Same thing.... So, I guess progamming this thing via WiFi is a bust. Good thing I also ordered the PC Link. Ill give that a try next, via my laptop.
Now i guess i have to attempt to contact the seller via Flea-bay, and let them know one of the ESC's was DOA, and see if I can get a replacement ASAP, the only issue is they are out of HonKong, and i dont know how much its going to cost me to send it back to them!! They should just send me a new one, without me having to send the dead one back, IMO.... Or pay for the shipping back to them. Ill see what they say. If they dont treat me right, Ill go the PayPal route and do a chargeback, I guess...
Anyways, thats my experience. I have no doubt this working ESC will be awesome, and I understand that these things happen, its just a bit of a burn, that one is DOA, and the WiFi module and apps dont even work, with the working one. Maybe the software is just too new, and needs some tweaking.
Ginnz.
ginnz is offline
Old 11-29-2015, 08:26 PM
  #773
Tim Mcpherson's Avatar
I run my first race weekend with my new TORO ts 150 in my 4 wh sct . 14 hour day of practice and a day of heats, dash for cash, and A mains it preformed flawless I cant wait to get one in my E Buggy.
The wifi works really well with my I phone. I bought mine from CRPPLUS.com a friend of mine got one off Ebay and pluged into batt out came a puff of smoke and it was over
Tim Mcpherson is offline
Old 12-01-2015, 07:21 PM
  #774
RC Juice's Avatar
Trader Rating: 140 (100%+)
Ginnz.
There is upgraded firmware available for the TS120, if you plug it into your PC with the SkyLink and launch the app you'll be able to install the new firmware and that may resolve your connectivity issue.
RC Juice is offline
Old 12-03-2015, 11:59 AM
  #775
Dino_D's Avatar
Correction. The Plastic one was approved a while back. Last year if I recall correctly. But the aluminum is not. But this is for Stock No Timing Race events.
http://www.roarracing.com/approved_non_timing_escs.php
Although the TS-120 plastic and aluminum in appearance look the same except for the case, the firmware is a bit different. The plastic use an older firmware while the newer aluminum case version use the same firmware as the TS-160. An no, I can't flash the plastic version to the newer firmware in the aluminum case.
Not sure about the newer crop of plastic SKYRC 120a, if the firmware is udpated.
Dino_D is offline
Old 12-04-2015, 05:10 AM
  #776
Djchow85's Avatar
Anyone using the 160a version of this? I ordered this as my gen2 Hk esc died after 10 cycles and wanted to re use the Wi-Fi dongle which works on the hk. My only concern was if the capacitors blew.. And if you could replace them internally for the 160a version.
Djchow85 is offline
Old 12-04-2015, 12:23 PM
  #777
I would think the WiFi box would work with the Toro TS160 as well
Old 12-06-2015, 01:00 AM
  #778
Jack Smash's Avatar
Trader Rating: 35 (100%+)
Wifi works great on both of my 120's ans my 160
Jack Smash is offline
Old 12-06-2015, 02:54 AM
  #779
Djchow85's Avatar
The capacitors can't be replaced in the 160 can they?
Djchow85 is offline
Old 12-06-2015, 11:00 AM
  #780
no they are soldered to the board
