Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 09-04-2013 | 11:44 AM
  #991
Originally Posted by Randy_Pike
Please do this to verify instillation:
Unplug the esc from the Hotwire.
Launch the Hotwire software, hit the help button.
What version is shown?
Version 9.6.1
X God is offline
Old 09-04-2013 | 12:52 PM
  #992
Randy_Pike's Avatar
Team Tekin
Originally Posted by X God
Version 9.6.1
Perfect.
Now are you hooking up the Hotwire to the esc via the servo lead or programming port on a Gen2 esc?
Randy_Pike is offline
Old 09-04-2013 | 01:06 PM
  #993
Perfect.
Programming port but I did try the servo lead with the same results
X God is offline
Old 09-04-2013 | 02:46 PM
  #994
Randy_Pike's Avatar
Team Tekin
Ok, does the Hotwire light up with a single green led? Does your esc power up showing one red flickering led when connected to the Hotwire?
Old 09-04-2013 | 02:56 PM
  #995
Hotwire-No lights
ESC-Far left led(DB) on steady if connected thru programming port
Center led (NW) if connected thru servo lead
X God is offline
Old 09-04-2013 | 03:17 PM
  #996
Randy_Pike's Avatar
Team Tekin
Hotwire-No lights
No led's on the hotwire is odd. Did you 100% make sure it's fully seated onto the USB cable? The housing can be a tight fit and even at times require a trim.
If that's verified, your Hotwire may need repair/replacement.
Old 09-04-2013 | 03:43 PM
  #997
Verified. Don't know if it's worth getting repaired or replacing it since it actually works except for the lights and speed type. I know what I have it plugged into. LOL. What do you guys charge for repair ? Thanks
X God is offline
Old 09-04-2013 | 03:44 PM
  #998
Randy_Pike's Avatar
Team Tekin
"Speed type" ???
Old 09-04-2013 | 03:47 PM
  #999
Verified. Don't know if it's worth getting repaired or replacing it since it actually works except for the lights and ESC model. I know what I have it plugged into. LOL. What do you guys charge for repair ? Thanks
X God is offline
Old 09-04-2013 | 04:24 PM
  #1000
Waflet's Avatar
Hideeho
Getting the hotwire repaired, not rx8.
Waflet is offline
Old 09-04-2013 | 04:58 PM
  #1001
keidel's Avatar
Default ESC Type
While my Rx8 gen 2 is connected to the hotwire under the advance tab it shows esc type as unknown. If I connect gen 1 Rx8 or rs pro it shows what esc is connected. Nothing is wrong and works fine was just curious why type of esc is shown as unkown.
keidel is offline
Old 09-04-2013 | 09:27 PM
  #1002
Randy_Pike's Avatar
Team Tekin
You need to updated your Hotwire software:
www.teamtekin.com/hotwire.html
Old 09-05-2013 | 06:54 AM
  #1003
keidel's Avatar
I just installed the newest software yesterday so I thought. Two other people useing gen 2 say theirs says same thing. I won't be home till later to do any trouble shooting. I will check which version later seen how to do that on a post yesterday.
keidel is offline
Old 09-05-2013 | 07:37 AM
  #1004
Graham11's Avatar
I just installed the newest software yesterday so I thought. Two other people useing gen 2 say theirs says same thing. I won't be home later to do any trouble shooting. I will check which version later seen how to do that on a post yesterday.
i thought i had the newest too but i had to update, i think it was from 238 to 239
Graham11 is offline
Old 09-05-2013 | 09:46 AM
  #1005
Randy_Pike's Avatar
Team Tekin
To verify:
Plug in ONLY the hotwire to your computer, no esc. Launch the software, hit the "help" button. The version should read 9.6.1 at the moment.
