Lithium battery charging question
Not sure if anyone here can help, I have a 1:1 race car and have bought a Braille lithium battery (G9) I have a Turnigy charger for my TC and I can select 11.1V (3 cell) or 14.8V (4 cell) the Braille charger has an output of 13.8-14.4V at 2-10amps dependant on the charger, is it OK to use the Turnigy ? if so what settings
Suspended
Charger Specs.
Model Name
1232L
Model SKU
1232L
Output Amperage
2a
Amp Hour
2
Voltage
12
Voltage Output
13.8-14.4
Voltage Input
110/220
Output Connectors
Med. Clamps & Ring
Battery AH Usage Range
< 200ah
Input Voltage Socket Plugs
USA
Reverse Polarity Protection
Yes
Microprocessor Control
YES I would charge on 2amps and 3 cells lipo
Model Name
1232L
Model SKU
1232L
Output Amperage
2a
Amp Hour
2
Voltage
12
Voltage Output
13.8-14.4
Voltage Input
110/220
Output Connectors
Med. Clamps & Ring
< 200ah
USA
Yes
There are different types of lithium batteries, I suggest first determining what they are to get the correct charger settings. I suspect none of the mentioned lithium polymer (lipo) settings are appropriate.
The Braille site calls them lithium ion (li ion), but from the voltage specs they might be lithium iron phosphate (LiFePO4). I know of others who have used 4S A123 LiFePO4 batteries in vehicles as a direct substitution like these apparently are.
I don’t know if the Turnigy charger has all of the lithium type charge settings, probably does.
Not sure which Turnigy charger you have, but I just looked at an Accucell 6 manual, you may have to go into User Set Program to get it to a different lithium mode.
Life nominal voltage is 3.3V, maximum of 3.6V. 4 cells of 3.6 = 14.4V, same as the maximum of the Braille charger specs.
