Tekin RS Gen 2
Tekin RS Gen 2
The RS GEN2 brushless speed control is the next generation in intelligent operating motor drive technology. Continuing the proven award-winning legacy of the RS familly, the GEN2 is fitted with todays state of the art components. The RS GEN2 delivers what racers require; reliability, precise control and unmatched power handling capability.
Packed with new features, the RS GEN2 delivers a programmable high-voltage BEC, an EZ Access Port for HotWire communication and Datalogging capabilities in a small sized package. Rated for 8.5 turn motors and higher, the GEN2 is the perfect ESC for both experienced and new racers. Couple the RS GEN2 with a Redline GEN2 brushless motor for the ultimate package in race equipment.
Features:
Ultra-smooth and Precise Throttle and Braking Control
Compatible with Sensored/Sensorless Brushless and Brushed Motors
Easily Access Programming, Anywhere, Anytime
Datalogging Capability
High Voltage Programmable BEC
EZ Access HotWire Programming Port
HotWire PC Interface for Advanced Programming and Updating
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
HDAC: High Density Copper PCB's
Sensor Plug for Precise Commutation with all Motors
Gold-plated Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune™ Programming
One-Touch Radio Calibration
Program Features:
High Voltage BEC (6.0v/7.4v)*
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (13 steps)
Timing Profiles (5 preset - 2 custom*)
Adjustable Throttle and Brake Minimums
Custom Throttle Curves
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2S, 3S, Custom)
Timing Boost and Turbo when used with Hotwire
ROAR Race Spec "Blinky" Mode
Save, Load and Share custom ESC setup files
Extensive Tuning via Tekin HotWire PC Interface
*Requires HotWire Sold Seperately
SPECS:
Controls: Forward/Brake/Reverse
Input Voltage: 4-9 Cells, 2S-3S Lipo
BEC: 6.0v / 7.4v 5.5amps
Motor Limit Brushless Mode: 8.5 Turn, 540 2-pole (36mm)
Motor Limit Brushed Fwd Only Mode: 10 Turn
Motor Limit Brushed Fwd/Rev Mode: 12 Turn
Timing Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.0 x 1.3 x .51in (25.4 x 33 x 12.9mm)
Weight: 2.0oz / 48g with wiring
http://rcinsider.com/?p=45254
Features:
Pit Tune Mode
Program Features:
SPECS:
Glad I picked up a Duratrax DE10 for my DESC210R since Randy hinted this was on the horizon. Wonder what new features it will have programming wise?
It's got some new goodies that I'm really excited about. It is VERY smooth, great braking. I'll let you guys know more when I can! It will be an awesome mild-mod, super stock and stock controller.
Yes on smoothness, it has a great feel. Yes on the white cases. Black will be available but I love the white, it stands out and pops!
