Viper Copperhead VTX4.5R >
Old 03-10-2013 | 04:37 PM
shipwama's Avatar
Default Viper Copperhead VTX4.5R
Hello I got this setup to get me going on a budget in my 4x4sc, NOW i got it in and am just looking at 2 things, the wiring from the ESC to the motor. there isnt any labels on them as to which spot they plug into on the ESC...
secondly i am going to start at a 14 tooth pinion, how do i check/ verify that i am too many or too few theeth on the pinion
THANKS all for your help
shipwama is offline
Old 03-10-2013 | 07:32 PM
nikos2002's Avatar
For the wiring - its an unsensored unit so plug it in and give it little throttle, if it goes backwards, switch two connectors and verify.
There is a basic gear chart in the instruction manual, or you can let me know what chassis you have we can put you in the ball park. Always better to start one tooth lower, just to make sure temps aren't bad, but it can leave room for improvement.
nikos2002 is offline
Old 03-10-2013 | 07:44 PM
shipwama's Avatar
i am running the tekno sct410
shipwama is offline
Old 03-10-2013 | 08:57 PM
nikos2002's Avatar
I believe that is similar to the Losi, so you would want to look like a 13-14 to start with. Like I mentioned before, you always want to stop and check temps first min or two at first just to be sure you're in the ball park.
Old 03-10-2013 | 09:27 PM
Hoese37's Avatar
I dunno. I was told by both a Viper driver and a dealer to not run the copperhead system. Its not a good choice for racing a 4wd sc. You want an 1/8 esc.
Hoese37 is offline
Old 03-12-2013 | 05:52 AM
nikos2002's Avatar
I won't say its not good for racing, its an option for many reasons.
1) price - can't beat the price for level of performance you get
2) set up - super easy to set up
3) maintenance - super easy to maintain
4) performance - testing has shown that it has speed and power to compete with higher end systems
5) ProGauge - adjustable just like our "pro" series, with even more straight forward adjustments
I lent a young man a Copperhead system at Motorama this year, he had the 7th fastest overall time - and 11th overall in qual point. He literally put the system in his truck Friday, practiced 3 times with it and almost made the A Main against a good number of factory drivers. And our team drivers have used it at several 4wd SC events over the last year.
Don't knock up, til you try it. BTW, you can run the popular (expensive) 4 pole motor with it as well, been told it works pretty good.
Old 03-15-2014 | 03:39 PM
Angry Viper copperhead
Slash with viper copperhead 4.9 got wet and just died.puddle was just enough to get truck wet and i just smelled burned electronics.is this normal for this system or should i try something to see if it will work?
Vikingbruno is offline
