PROTEK SERVO Questions >
Like Tree1Likes
Old 08-01-2015 | 11:08 PM
  #151
Brought a 130t and 130ss emailed amain with jittering issues on the 130ss had no reply servo done 3 race meetings and stopped completely inspect thinking I stripped a gear as was jammed solid gears are mint and a scorch mark under motor. Don't recommend them if you are international as amain doesn't seem to care if you aren't local
Pollockmarine is offline
Old 08-02-2015 | 01:23 AM
  #152
I must say that has been far from my experience as an international customer of AMain.
What email are you writing to?
cplus is offline
Old 08-02-2015 | 02:14 AM
  #153
There customer support option on there web page and there Facebook page, bit of shame as they were good at charging and shipping products but ldropped the ball on support
Old 08-02-2015 | 04:42 AM
  #154
fizzy's Avatar
Amain customer service has been top notch for me and I'm international also any issue I have ever had has been resolved almost immediately by there support people I would suggest you contact them again I'm sure they will look after you
fizzy is offline
Old 08-02-2015 | 03:47 PM
  #155
Email: [email protected]
Also, try the online chat. I've found the guys on the end of that very helpful.
There is also a thread dedicated to Amain here and the customer service guys are quite active in that.
cplus is offline
Old 08-13-2015 | 02:13 PM
  #156
I have protek 130ss and 130t what should be my settings to zero them in on my Futaba 4pls. Or what you guys set yours to many all of it.
lighttravler is offline
Old 08-17-2015 | 01:44 PM
  #157
utieh's Avatar
Budget racer here.
I was curious to know if the 100T would be a good choice for a RC10T5m (stock racing).
Thanks for the help.
utieh is offline
Old 03-18-2017 | 07:15 PM
  #158
TJames987's Avatar
my brand new protek100 servos failed 1st race day out. demanding a refund from amain.
Originally Posted by mkorn
The ProTek servos have been tested in every imaginable way, and then tested again. We had a year of real world on track data and testing before a single servo was put up for sale.
We had clear goals in mind for the ProTek servo project.
1. Make the best servos available.
2. Test, test, test until every single team driver was 100% happy with each servos performance.
3. Assure durability for a minimum of 1 year. We had 0 failures during this testing period!
4. The ability to offer the entire servo line at unmatched pricing.
We achieved all of our goals and are extremely proud of the project. We stand behind anything we sell and we hope you all enjoy them. If you have any questions about any ProTek products my information is in my signature.
TJames987 is offline
Old 03-18-2017 | 08:13 PM
  #159
1/8 IC Fan's Avatar
This seems to be happening more and more with the 100 and 130 series. I (knock on wood) have not had any issues with mine sofar.
1/8 IC Fan is offline
Old 03-27-2017 | 07:09 PM
  #160
JAE
Protek 150 and 160t are great. Super smooth and fast. But having an issue with Exotek and AE 25t servo horns coming lose.anyone experience this? A lot less with loctite but eventually develop some play more vertically in back and forth rather than side to side . Anyone else?
JAE is offline
Old 03-27-2017 | 08:41 PM
  #161
Randy_Pike's Avatar
Team Tekin
I highly recommend using the clamping horns. Exotek and Protek both offer them for AE cars specifically. HERE
1/8 IC Fan likes this.
Randy_Pike is offline
Old 03-27-2017 | 08:42 PM
  #162
Randy_Pike's Avatar
Team Tekin
Originally Posted by utieh
Budget racer here.
It would be fine but I'd suggest the 100SS over the T. The T is a bit slow. The torque is more than enough on the 100SS for a 2wd ST truck.
Old 03-27-2017 | 08:43 PM
  #163
Randy_Pike's Avatar
Team Tekin
Your radio settings simply need to center the servo before placing the horn. Then set your EPA or Travel to assure your servo is getting the proper left and right travel while not over travelling which is often the single biggest reason for servo failure.
Old 03-27-2017 | 08:56 PM
  #164
JAE
I have 2 Exotek clamping horns that are giving me a little wobble backwards and forwards. You happen to know the length of the screw needed? Perhaps that could be a culprit
JAE is offline
Old 03-27-2017 | 09:00 PM
  #165
1/8 IC Fan's Avatar
The 170T's are getting it done in the buggy, and the 100SS is still rocking in the Buri Racer! 150T has also been holding on in the E-truggy. Run them all on 6V BEC.
I always use the Protek clamping arms, never have tried another servo Arm / Horn. Run the protek 3x12mm set screws, with a washer and locking nut, not once have i had servo arm issues! I tighten first, then clamp, then loosen the 3mm locknut, recheck the clamp, then final tighten the locknut.
