tekin rx8 question
Ok well background. I have a losing scte with the rx8 and 5200kv tenshock s411 motor. My lipos are not discharging evenly when I am using them. The will be balanced previous to use but 1 cell will be down to low. So its not even. What could be wrong
My guess is you have a battery that is not any good. I would look at replacing that battery as a lipo that does not balance right is going to prove unstable sooner than later.
Suspended
U dont need Good batteries You Need High Discharge batteries.That actually deliver what they say... some just dont have what the label says Like nano techs..FYI there is no such thing as a 50C lipo false info at max the lipo cells can deliver is 32C Max and 50C burst for 2-5 seconds..
Its your batteries thats the only problem in this POST..
It's true...anything more than about 40c is just smoke and mirrors. When one company advertises a 65c pack the rest have to follow or risk losing sales. It's truly unfortunate for the consumer that there isn't a standardized testing procedure for lipo cells.
The current limit doesn't limit the max current overall, just how much it uses from a dead stop where electric motors make their most torque.
My truck pulls over 4000 mah out of the battery in a 5 minute heat, so it's pushing 2s to the limit, whatever that limit may be. There is only 1 long straight at my track, and the rest is medium-slow finesse with a double-triple, and some technical bits, so imagine how many amps it's pulling WOT if i'm barely on-throttle the rest of the time.
