Electric starter
Old 12-08-2012 | 05:12 PM
Dark Flames's Avatar
Default Electric starter
Hey guy i got myself my first buggy, and it's nitro, but after two day i've snapped the pullstart rope, i have a Thunder tiger eb4 s3, and i was wondering if i could put an electric starter on it, and are they compatible from model to model, or will i need to track down a specific one
Dark Flames is offline
Old 12-08-2012 | 06:26 PM
the best way for an electric starter is to get a starter box. its basicly a box you set the car on, it has an electric in it with a rubber wheel, it presses up against the flywheel and turn the motor over. its a far better way of starting a nitro engine than a roto-start setup. rotostarts are very hard on one way bearings. if you are careful with it they are ok, however most people end up chewing through a few one way bearings before they learn. my personal view is stick with a starter box unless you have a vehicle that you cant use one (i use a rotostart on my savage because its not possible to use a starter box).
another option is just to get another pullstarter. they arent that bad, most of the problems with them are because the motors are very tight when new, and you end up pulling too hard and breaking the string, or pulling too far. if the motor is new, id recommend pre-heating the motor for the first while till its fully broken in, this will help with some of the pullstart problems.
Sharkey_t is offline
Old 12-08-2012 | 06:40 PM
Hoese37's Avatar
If its got the thunder tiger .21 engine, you gould get one from a RTR Associated 1/8 vehicle.
Hoese37 is offline
Old 12-09-2012 | 04:11 AM
spoke to the guy at stanbridges, the tige engine is monted pretty high apparently, reckons it wouldn't reach the flywheel, anyway i'll try the electric drill started one, and i snapped the spring trying to repair my last one
