HobbyWing EZRun SC10/SC8 Problem? >
Old 11-07-2012 | 05:16 AM
Default HobbyWing EZRun SC10/SC8 Problem?
I am running a HobbyWing EZRun SC10/SC8 ESC in an Associated SC10 4x4 with a HobbyWing 4000kv motor and a 2S battery. The truck runs fine for about 2 to 3 minutes then only has about half power for about 8 to 10 seconds and finally shuts off. Once you turn it back on, it will run fine again for less than a minute and repeat the problem. The ESC is only getting up to about 115 degrees. Motor is not hot either. Any ideas?
ninefifteen is offline
Old 12-11-2012 | 01:54 PM
Slotmachine's Avatar
What batteries are you running? Make sure that you are getting a full charge, and what setting are you using on the speed-control?
Paul
Slotmachine is offline
Old 12-11-2012 | 02:34 PM
hotrod87's Avatar
Sounds like lipo cutoff. Definitely check your settings. Did you try another battery?
hotrod87 is offline
Old 12-11-2012 | 07:37 PM
Try manually programming your esc to the number of cells your running. Let us know the outcome
big JC is offline
