Servo Failure
Old 11-02-2012 | 12:29 PM
Default Servo Failure
I am currently running a futaba B451 in my sc10 4x4. Twice now I have had to replace the nylon gear in it. All the other gears are metal. The problem is you can't just buy the nylon gear you have to buy the whole set. At $36 a pop. Obviously each time it broke I hit a tube or had a hard landing but that was never a problem when I ran this servo in my SCTE. I am looing to try a Savox servo can someone recomend one that will survive in this truck? How much torque do I need in a servo for it to last.
roland5color is offline
Old 11-02-2012 | 01:02 PM
UrabusDenis's Avatar
Do you use a servo saver?
UrabusDenis is offline
Old 11-02-2012 | 01:35 PM
yes its built into the steering of the SC10
Old 11-02-2012 | 02:21 PM
Suspended
put one on your servo.. I have my SCTE setup that way..
tntpoof is offline
Old 11-02-2012 | 04:01 PM
I run a 2271SG in my 2WD ST. It's unbelievably fast, a bit pricey, and WAY overkill, but I never have to worry about damaging it.
ufoDziner is offline
Old 11-02-2012 | 06:50 PM
then you should back off the servo saver a bit. Stripping the gear twice is telling you the saver might be too tight.
goots is offline
Old 11-02-2012 | 07:49 PM
I always ran my SCTE servo saver tight and thought I could with this truck as well but I believe your right the servo saver needs to be looser on this truck. I had my hobby shop telling me that I needed a servo with more torque. Thanks for the replies
Old 11-03-2012 | 07:03 PM
Well I backed the servo saver off all the way and I made it through 3 qualifiers and a main without damaging the servo. So far so good thanks for the help guys.
Old 11-04-2012 | 06:07 PM
Thats good to hear. Just remember tightening your saver down all the way defeats the purpose of it being there at all.
goots is offline
Old 11-04-2012 | 07:21 PM
Odin544's Avatar
SCTE servo savor =/= SC10 4x4 servo saver. All of them are different and need to be adjusted accordingly.
I love Futaba servos. But I think thats a poor choice for that truck. I think a good one for that truck would be the ace/ds1015. For 4wd SC I'd be looking for >180 tq and <.10 speed. With the higher torque servos you normally get all metal gears because if they didn't put them in they would fail for sure. I don't personally care for Savox but a lot of people use them with out any issues. I'd look at the Savox 1258TG.
So in a way I agree with your local hobby shop. And just think, if it fails again you could have bought a brand new servo that is better suited to that truck for what you have spent fixing it.
Odin544 is offline
Old 11-05-2012 | 05:01 AM
lbenton's Avatar
If it is $36 each time you have to repair it, I would run it until it failed again and then simply take a moment to consider replacing the whole servo vs repairing it.
Just adds up too fast if it keeps breaking, worth buying your way out of that problem at some point.
lbenton is offline
Old 11-05-2012 | 06:08 AM
As for the servo saver you are correct Sr. I have learned my leason on that one. I guess I was spoiled by my losi cars and trucks. My 22 doesn't even have one. The B451 does have metal gears. Just the one is nylon or whatever material it is. Do you know of a servo that has all metal gears? My hobby shop also told me that all servos have at least one nylon gear is this correct? Oh and if it fails again I will definately be buying a servo with more torque.
Old 11-05-2012 | 07:04 AM
Suspended
Yes to all metal gears ..Hitec MG 900 series I run a MG 945 in one of my scte..also a MG985..My son who is alot more crash happy runs a BlueBird HS MG 626 fast and all metal can get them New for $30.. I bought a box of Hitecs along time ago for 100$ there was 12 used 900 servos in it..
tntpoof is offline
Old 11-05-2012 | 07:36 AM
awesome this is what I am looking for all metal. I will have to do some more research. Thanks
Old 11-07-2012 | 06:23 PM
dethklok151's Avatar
Fwiw, futaba may make a metal gear that would replace the nylon one. It would be for a different model but many times they will list the cross references somewhere. I dont remember the model numbers,but i have done this with some airtronics before.It may not be worth it to do this time but you can keep it in mind.
dethklok151 is offline
