SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 05-22-2013 | 05:18 PM
  #1276
Originally Posted by rjohn929
They are 2 cell batteries and you can run them safely down to 3.2 or so. I have my LVC set at about 3.5 just to be safe and give a little extra life to the packs. 1c will be 6.5 amps, I assume you mean for charging? If you have a good charger you can charge them much higher then that.
yes i herd they can take a 2c charge rate but im new to this and my charger also. My charger is the pl6 playing with it now but man there a lot in this guy to set up. so im trying to store the info for lipo up now.
imrob is offline
Old 05-22-2013 | 05:28 PM
  #1277
QuikWgn's Avatar
http://www.rchelicopterfun.com/rc-lipo-batteries.html
Try reading this...it might help...
QuikWgn is offline
Old 05-22-2013 | 06:22 PM
  #1278
Danny/SMC's Avatar
Company Representative
There really isn't much to setup in the PL6 they already have profiles created.
Use generic high power and set the charge amps to 13 and you should be all set.
For cutoff on your ESC you should use 3.4 to 3.5v per cell.
Danny/SMC is offline
Old 05-22-2013 | 09:02 PM
  #1279
Default Here is update please
Order Date: 16/05/2013
Order ID: 2175
Blackpearl#1 is offline
Old 05-22-2013 | 11:07 PM
  #1280
Suspended
Order Date: 22/05/2013
Order #2246
thanks
tryandfok is offline
Old 05-23-2013 | 05:38 AM
  #1281
R/C Tech Elite Member
I have two 4S SMC packs coming home soon. I can't wait to try them
Sylvain is offline
Old 05-23-2013 | 08:26 AM
  #1282
Danny/SMC's Avatar
Order ID: 2175
Your order is complete and will ship today.
Old 05-23-2013 | 08:28 AM
  #1283
Danny/SMC's Avatar
Order #2246
thanks
You ordered packs on pre-order and I expect your order to be complete around June 7th.
Only the models in my post above came in this week.
Old 05-23-2013 | 08:40 AM
  #1284
gawith0413's Avatar
Order #2246
thanks
You just did this order!
gawith0413 is offline
Old 05-23-2013 | 09:21 AM
  #1285
ok now i got it that was the way i needed it explained. now i understand why i need this charger and how you Guy get 13 amps it makes sense now thank you. and the discharge is like double the battery mah.
imrob is offline
Old 05-23-2013 | 09:31 AM
  #1286
ButtDyno's Avatar
Wow...been running my new SMC 7200 70c packs in the tekno...and damn it rips. Thanks SMC for putting out a BA battery for under $75...only packs I'll buy now.
ButtDyno is offline
Old 05-23-2013 | 10:52 AM
  #1287
QuikWgn's Avatar
I run a little different setup than most I imagine. I run 1/8th E-buggy only at the moment. I have 4 4S 6500mah packs that I bring with me charged to the track. First pack is warmup + heat 1, 2nd is for heat 2, 3rd is for BMain (if necessary), and 4th pack is for the AMain. I run my cutoff V in the ESC @3.6V( I almost never hit the cutoff). I then take them home and charge them at 1C (6.5A) to 3.8v(storage V), and then to full charge usually 1-2 days before my next race.
When doing storage cycling (like over the winter) I charge them to 3.8v(storage V) then once a month charge them @ 1C to full charge, and then discharge them @ 3C to 3.6v (my charger has a built in 30A discharge circuit appx 4.3C max) and then wait an hour and recharge them back to 3.8v(storage V). This is a really easy life cycle for my lipo packs and they seem to last alot longer this way.
QuikWgn is offline
Old 05-23-2013 | 11:00 AM
  #1288
mxnickj's Avatar
Can you give me an ETA of when you might have the 4S 6500 packs (#6570-4S2P) back in stock??
mxnickj is offline
Old 05-23-2013 | 11:05 AM
  #1289
Danny/SMC's Avatar
This model will be back in stock around the 7th of June with a big shipment of 7200-70C-2S Deans and Inboard.
Old 05-23-2013 | 11:06 AM
  #1290
Danny/SMC's Avatar
The 6500-60C-4S came in today and we're starting to ship out pre-orders. Unfortunately the pre-orders are using the entire shipment so there will be no packs available to list on the site.
