SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 05-23-2015 | 07:35 PM
  #3706
Originally Posted by fullyford
ok thats good news that i should be able to slit the hard case and resolder the balance lead.
on another note. one of my new smc 6500 60c batteries i did a balance charge on it before its first use. and i have run it 4 times since then. i right down every charge and how much mha goes in, and if i balance them. so it was the 5th run with this battery and it timed out on my charger and one cell was at 4.20 and the other was at 4.11. i turned the charger back on and tried again. it timed out two more times but finally got it to balance at 4.20/4.19
is this something i should be concerned about, is it possible that one cell is damaged?? this is a brand new battery.
for a charger i am using a hitech x4. with a power supply, not sure how big the power supply is though.
Not sure if it matters or not...but I only balance charge my batteries. I don't see any reason not to
4s losi is offline
Old 05-24-2015 | 10:47 AM
  #3707
rcjunky1's Avatar
Run it again then check the cells again, if it's way out of balance again talk to Danny, he'll probably want you to ship the pack to him and he'll do his voodoo on it. I had a pack where one cell doubled in resistance and did what you are described
rcjunky1 is offline
Old 05-24-2015 | 06:05 PM
  #3708
I have also done the balance cable re-soldering repair. Instead of splitting the case alone the seams, I cut off the end of the pack. This is a lot safer than trying to split the two halves of the pack apart. There is actually a little open space on the end by the wires/bullets to make space for the solder connections, so less chance of ruining the battery.
I'm throwing in an image so you can see how it turned out.
I glued mine back together with "Loctite Vinyl, Fabric & Plastic" glue. It was ideal, and I think better than shoe goo for this repair. The solvent in the glue will melt/soften the plastic, essentially welding the plastic together.
The repair has held up for 2 years, and the pack is still going strong!
fredygump is offline
Old 05-24-2015 | 06:37 PM
  #3709
I highly doubt it is a problem with the battery. But definitely I would balance every time. That might be part of the reason.
The other thing is that the safety time-out feature defaults to an arbitrary setting, which is on the short side. I would change it. The charger doesn't know how large your packs are, and the time limit doesn't change based on the state of charge of your battery.
I had a similar charger that did the safety time-out thing (single battery hitech charger). Atleast it sounds like a similar problem. After I changed the time limit, I never had a problem with it again.
Old 05-24-2015 | 10:56 PM
  #3710
Well I got the broken balance lead fixed. Was pretty nervous splitting the hard case but it went pretty good. I tinned the lead wire but had a heck of a time getting it to solder to the battery and I was using a 150amp gun. Took a lot of heat more than I thought. I took a couple pics I will try and upload.
fullyford is offline
Old 05-24-2015 | 11:08 PM
  #3711
here the pics i took. all that dirt on the bench came out of the battery. i wonder if i should shoe goo the wire opening to prevent dirt from getting in there.
Attached Thumbnails SMC LIPO BATTERY THREAD-photo1-15.jpg   SMC LIPO BATTERY THREAD-photo1-14.jpg   SMC LIPO BATTERY THREAD-photo1-13.jpg   SMC LIPO BATTERY THREAD-photo1-12.jpg
Old 05-24-2015 | 11:11 PM
  #3712
i have the timer set to 120 minutes. this was the first time i ever hit the time limit.
Old 05-25-2015 | 12:32 AM
  #3713
I bought some saddle packs a number of months ago and I think they are fantastic. I also bought some shortys from another "high end" brand when I switched chassis, which are, by comparison, junk. I've got to say Iam very impressed with the SMC product. Just wish I could find somewhere in the UK that stock the shortys.
Piles is offline
Old 05-25-2015 | 09:09 AM
  #3714
the wrench's Avatar
trying to find some info, i started a thread about batteries and a few people mentioned smc packs, i read through this thread and im sold on smc... sent an email through the smc webstore. is there a new 4s pack coming within a few weeks or should i just pre-order the existing 6500mah pack? and those who race ebuggy, do you prefer the single 4s or double up 2s packs?
the wrench is offline
Old 06-11-2015 | 01:32 PM
  #3715
sleddriver's Avatar
Probably a little late here but YES, the new SMC 4S pack is listed as 6700mAh 60C extended capacity which means the mAh is around 7200mAh. $79.95. Danny has a picture on his website of this battery taking 7339 mAh! It's not huge either, the hard case is 47mm x 47mm x 139mm and weighs 629g. I don't believe there's a better 4S battery out there.
sleddriver is offline
Old 06-11-2015 | 01:40 PM
  #3716
sleddriver's Avatar
Originally Posted by coombes
So you are saying really its a 7200 but in a 6700 liable am I right
That is exactly what Danny is saying too and this battery is available now.
http://www.smc-racing.net/index.php?...product_id=277
Old 06-11-2015 | 02:11 PM
  #3717
Hoese37's Avatar
Hoese37 is offline
Old 06-22-2015 | 07:24 PM
  #3718
Suspended
i just picked up two of these lipos cant wait to try them out
FGomez50 is offline
Old 06-22-2015 | 07:25 PM
  #3719
Suspended
Anyone try the smc 1/8 scale motor yet and how good is it?
FGomez50 is offline
Old 06-22-2015 | 07:32 PM
  #3720
Have two of these. They work excellent. No issues at all. Just as powerful as any comparable motor
4s losi is offline
