Dumb M11x question
Did you experiment with throttle expo?
your EPA is probably too high...
1st ..what servo are you using ?
Here.TH] in EPA.
To adjust the high end of throttle movement on a gas powered car, pull the
throttle trigger all the way to the high side and adjust by pressing the Inc.+
or Dec.- key.
To adjust the brake side, push the throttle trigger all the way to the brake
side and adjust by pressing the Inc.+ or Dec.- key.
With an ESC, the high side and brake side are both ordinarily set to 100%
and then the high point and brake point are set on the ESC.
(Setting procedures may vary depending on the type of ESC.)
Setting range 0% to 140%
Brake side 0% to 160%
Standard setting 100%
Test run your vehicle to set the brake adjustment by using TRM5 switch on
the grip. You can vary the setting at EPA-B by adjusting with TRM5. While
the M11 is set for 4 channels, setting value may vary at the same time.
Here.TH] in EPA.
or Dec.- key.
Here.TH] in EPA.
or Dec.- key.
Here.TH] in EPA.
or Dec.- key.
Thanks, Mike
