Help with Spektrum Dx3r!!!! >
Old 10-26-2012 | 06:38 PM
HPI-Blitz 101's Avatar
Default Help with Spektrum Dx3r!!!!
I have a DX3r and I cant get it to calibrate to my Tekin RS but my stock radio will.
What end points and frame rate and travel do you guys set yours to?
It has a Savox servo in it as well.
Thanks!
HPI-Blitz 101 is offline
Old 10-26-2012 | 06:51 PM
Thanks!
You may need to the throttle servo setting for it to be Norm for the Tekin to recognize the radio.
The other thing is to be sure the Tekin's Deadband is 20 or higher.
AreCee is offline
Old 10-26-2012 | 07:09 PM
what is the deadband?
Old 10-26-2012 | 08:08 PM
Neutral width (LED4).
AreCee is offline
Old 10-27-2012 | 08:09 PM
What should I set the travel rate to on my brakes,steering and throttle on my TX?
Thanks!
Old 10-27-2012 | 08:25 PM
klaymon's Avatar
Your throttle/brake EPAs should all be set to 100% for calibration.
klaymon is offline
Old 10-29-2012 | 07:44 AM
UrabusDenis's Avatar
Thanks!
When calibrating a ESC, all your parameters should be 100%, as stated above. When the calibration is succesfull, then you can adjust them to your liking
UrabusDenis is offline
