New LRP Flow Esc
#1741
I just got a Flow X today and I'm trying to calibrate the radio with no luck. Everything is connected properly. When I push the set button the green light comes on, but only as long as I hold it there. As soon as I release, it goes back to blue. Any help would be appreciated
#1742
Hello,
Yesterday I broke the wires of my on-off switch lrp flow esc,
the wires are located inside of the esc box.
Does anyone knows how to open the esc box and solder these two little wires?
Thanks for the help
Thanks for the help
#1743
Turn the ESC over and you will see 4 screws on the corners. Take the screws out and it will come apart. Then locate the area on the board where the switch is soldered to and re-solder. Just be mindful which wire is positive and which is negative. Also, when you're done soldering, make sure you didn't cross the solder stream with any other soldering point.
#1745
My ESC act weird on low speed, the red LED keep pop on when i hit the throttle gently, it only happens when the motor have some load on it, at low speed the ESC make the motor clunking noise, it works fine when tire not touch the ground. I already check the drive train, noting binding. And the motor works fine when i use another ESC. Here is the video below. Does anyone know what is wrong with my ESC. Thanks.
https://www.youtube.com/watch?v=D9YXg1iCGTY
#1751
#1754
Currently looking for a popular pairing for 17.5 TC class. Is there any motors that are running with better luck? I just was curious to see if they are any other alternatives to TSR, or Fantom motors that can run with these guys.
#1755
21Likes
