Like Tree21Likes
New LRP Flow Esc
Old 03-01-2017 | 07:55 PM
  #1696
silden's Avatar
Originally Posted by gigaplex
If it's plugged in backwards, reversing it will make a difference
How it's even possible to reverse the sensor wire in the first place? the connector is keyed in.
The reversing will fry the sensor board with a high chance.
gigaplex likes this.
silden is offline
Old 03-06-2017 | 06:14 PM
  #1697
nova2015's Avatar
Just updated my Flow Comp with V5.4 stock firmware, did initial setup, but motor will not run. Thinking maybe corrupted software I downloaded a new one, but no joy.
Ideas anyone?
nova2015 is offline
Old 03-06-2017 | 06:30 PM
  #1698
silden's Avatar
You have to do a Factory reset.
hold the set button while switching the ESC on.
What is the LED indication?
Are cables connected correctly?
silden is offline
Old 03-06-2017 | 07:08 PM
  #1699
nova2015's Avatar
Thank you, factory reset did the trick. I thought I only needed to do radio calibration.
nova2015 is offline
Old 03-07-2017 | 09:35 PM
  #1700
Ok, I am not happy at the moment.
When the FlowX became available, I bought two, one for my Touring, one for my Offroad. I was expecting LRP to do the same thing, to allow diff software to run on the same hardware for different purpose (onroad, offroad). However now LRP announces that they will come out with a completely diff model off road, changing their previous approach. Why would they do that? Since when did ESC hardware become so specific? As far as I can tell the only diff is that the wiring is longer in the offroad version... seriously?
SoLost is offline
Old 03-07-2017 | 11:32 PM
  #1701
silden's Avatar
The only hardware difference is the length of the servo and the supplyed sensor cable. The software can be loaded to any hardware version. We only have to wait until the adaptor comes out.
silden is offline
Old 03-09-2017 | 01:45 AM
  #1702
That would be excellent news. May I ask where you obtained the info? LRP has to be one of the companies with the worst communication.
SoLost is offline
Old 03-09-2017 | 07:31 AM
  #1703
silden's Avatar
This info is from their facebook page. A user asked about the compatibility of the LRP USB bridge 2 and the upcoming firmware.
The answer from LRP was that a new USB connector will come out and that the different Firmwares can be loaded to the FlowX.
BTW the communication problem only persists here in the US. I don't know why, but I hope that is getting better after AKA is the new US distributor.
silden is offline
Old 03-12-2017 | 11:46 PM
  #1704
Thanks Siden.
But allowing diff firmware to be loaded does not make the FlowX 'optimized' for both touring and offroad. They can release just touring firmware for the FlowX TC if they decide to The fact that FlowX Offroad and TC are two different SKUs are worrking.
and btw, no, I am from HK, communication is just as bad.
SoLost is offline
Old 03-19-2017 | 01:06 AM
  #1705
Originally Posted by howardcano
I haven't received it. Further, I have received no communications from LRP regarding it. I suppose they could have sent it to the wrong person, but I can't imagine who that might be; the ROAR application form hasn't changed in several years, and that's still my address at the bottom of the form:
http://www.roarracing.com/downloads/...R_ESC_FORM.pdf
Any updates on the ROAR approval for the Flow X ??
TypeR01 is offline
Old 03-19-2017 | 05:53 AM
  #1706
howardcano's Avatar
Received for testing!
dawgmeat likes this.
howardcano is offline
Old 03-20-2017 | 12:46 AM
  #1707
Excellent thanks for the reply
TypeR01 is offline
Old 04-11-2017 | 11:04 PM
  #1708
Korey Harbke's Avatar
In case anyone missed it, the FlowX is now on the ROAR approved non-timing/blinky ESC list!
Korey Harbke is offline
Old 04-26-2017 | 11:32 PM
  #1709
bornox's Avatar
hi guys! have a question about the flow x. is there a new usb drive for this esc or can i use the v2 usb bridge?
bornox is offline
Old 04-27-2017 | 07:27 AM
  #1710
Its not compatible with the old usb bridge. A new one isnt published yet.
Worst87 is offline
