Can i discharge Unbalanced lipos?
Ok guys, i'm freaking out here. Its the first time my lipos have ever been unbalanced. Basically this is what happened. My 2s lipo only showed one cell, and didn't show the other one. I could still charge it, but can't balance charge. I noticed that the balance connector on the lipo was hanging. So i cut the wires, and soldered it onto my balance adapters. Those adapters were made just to lengthen the wire so they were the same. Once i got done, i checked my charger. The cell's were around 1.85V and the other one was around 5.10V. OMG I'm freaking out. I searched on google, and it said something about discharging it and putting it into salt water for a few days. But is it ok to discharge it with my charger. I'm pretty scared lol. Any ideas? Also, the battery was at storage voltage when that happened.
Odd. Even if the cell is 1.85 might be dead. But for the other to be 5 is impossible.
Check the sequence of the conenctions 0 - 3.7 - 7.4V
Pretty weird. I'm not trolling you or anything. I've already resoldered the wires and see if that worked, but it didn't. Heres a picture.
Put the battery on a friends charger and see where it at. Im saying this to eliminate your charger. If their charger says the same thing, then the battery is bad, if not, then its your charger..
Some chargers have a "monitor" option, where it will monitor the battery and see where the voltage is per cell. So that way, its not trying to charge it, just reading voltage.
Discharge the pack using a light bulb outside until the bulb goes out, then let it soak in some salt water for a couple days and toss in the trash.
I've seen a couple batteries where the balance wires or connector has an issue and it doesn't read correctly. I had a thunderpower battery like this. One of the little balance wires broke inside the case and it would read strange voltages if you hooked up the balance connector.
Even on my good batteries, if I plug only my balance connector into my charger, but not the charge lead, it will show a set of voltages like you have posted.
Is the battery puffed up?
It might actually be ok, but just won't let you balance charge. You would definitely want to keep a closer eye on it, but it might just be giving you false readings due to a bad connection in the balance wires, or the wires being in the wrong order.
A LiPo cell over 4.5V would've bloated up and/or burst into flames. It's an error with the balancing wires, you probably messed up the order.
Sorry for the late response, totally forgot all about this thread. Anyways, the problem wasn't the charger's fault. I have two chargers, and they both read the same thing. I opened up the lipo, and i found a tiny broken off balance wire. I soldered that in place, and it's as good as new again!
