coging with cc bec
so i was getting brown outs with my spektrum 6040 servo and my sv2 esc.
the brownouts started after i ran at least 20-30 packs with no problem.
so i installed the cc 10amp bec.
and now it cogs hjas anyone heard of this with the bec.
with a reciever pack it works great.
and the motor is a cc 1410 3800.
what else could i do to fix this problem.
thanks for any and all advice.
mike
mike
If it is indeed "cogging" that you are experiencing its unlikely to be related to the external bec
Does the ESC calibrate correctly to your transmitter ?
What ESC settings are you using ?
You can try rolling back the software revision on the ESC, it often fixes random problems
Cheers
Cheers
the red wire has been removed.
it works fine with a reciever pack.
im wondering if the speedo is on its way out.
it worked fine for 25 or more packs just started to brown out.
i was going to get a mmp but ive heard i could have the same probllem with that as well
maybe its not coging but its stuttering like when i hit the throtle it accelerates but on and off
my radio is a 3pmx nothing set on the settings full power throttle
There are a few things that could cause this problem.
Binding in the linkage:
Remove the servo horn & check for any bind in the linkages.This can cause a servo to pull more amps than either of your bec 's can provide & cause the motor to cog on take off.
Check your servo:
Rapidly turn the steering back & forth ( with the transmitter) & check if the servo is getting hot.
A receiver battery pack of 1700ma should be able to supply more amperage than a 10 amp bec.
Also like was mentioned earlier your main battery could be weak.
A watt meter wired in line with your bec or servo would tell you if you are exceeding your bec's ability.
A Watt meter is what I use to diagnose my radio system for these problems.
An example of a watt meter
http://www.focalprice.com/YOE03B/100...Fc2a7QodgnSbkA
Most hobby shops carry some brand of one as they are commonly used in rc
Hope this helps
Tom M.
Check your servo:
Hope this helps
Tom M.
