MT4 binding issues
Old 05-25-2012 | 06:24 AM
embryoguy's Avatar
Default MT4 binding issues
trying to bind my airtronics mt4, but the throttle is not active. i see the lights on the esc react when throttle is pushed but no action.
it sometimes comes on 5-10 minutes later. the fan on the esc stays on.
thanks for the help.
embryoguy is offline
Old 05-25-2012 | 12:47 PM
dtr's Avatar
dtr
After binding the receiver to the transmitter you have to calibrate the ESC to the radio. Have you done so?
dtr is offline
Old 05-25-2012 | 01:06 PM
embryoguy's Avatar
how can i calibrate esc to throttle if the throttle wont even activate?
thank you for your help
Old 05-25-2012 | 01:39 PM
You said yourself that you see the lights change on the esc when you move the throttle. So, you should recalibrate your esc to the transmitter like dtr said.
ufoDziner is offline
Old 05-25-2012 | 03:08 PM
dtr's Avatar
dtr
Check the manual of your ESC, the calibration procedure is described there.
dtr is offline
Old 05-25-2012 | 09:11 PM
embryoguy's Avatar
thanks very much guys! it worked!! thanks again!
