Futaba 4PK Super R
#106
Ok so I think this ProTek life battery is ok, I charge it on my Hyperion it shuts off at 7.2v and then I put it in the radio and it drops to 6.8v very fast in like 3min, and that's why I thought it was bad but then it held from 6.8 to 6.7v for a little over 3hrs then I shut it off. I should be able to run it down to almost 6v so that is plenty of time a shit ton more than the factory one. U guys that have the same ProTek battery 2 cell 6.6v 2100mAh does yours do that where it drops from 7.2v to 6.9 6.8v quickly?
#107
I just bought a 4PKS-R. I think this is the first radio I have ever owned that comes set to "50/50" by default.
I tried to set it to "70/30" but now I am unable to readjust the neutral point.
https://www.youtube.com/watch?v=Gl1QDeCgsrw
What I have done:
MENU 2 -> THMOD -> MODE -> FWD70/BRK30 -> END
MENU 2 -> ADJST -> THROTTLE -> readjust stuff -> END
Attached is what my throttle servo screen looks like. You can see that the throttle neutral did not reset after the "ADJST" procedure. What did I do wrong?
What I have done:
#108
R/C Tech Elite Member
Trader Rating: 123 (100%+)
What is anyone doing for a case for these radios? I am looking for metal and pre-cut foam insert. Before you say "Amain", I want mine to say "FUTABA" on it.
#109
Skip the futaba part. The cases are not all that high of quality compared to say a pelican case. You drop and bang around those metal cases and they get dented and scuffed. You can run over a pelican case with a car. I used a pelican 1450 with mine. The foam is a pluck it out to fit what ever you want kind of thing. And if you get a new radio in the future you can order a new foam insert.
#111
Is your transmitter antenna broken?
#113
Having a strange issue with binding rx's. I have the 4pks-r with 2 R614FF-E and 2 R603FS receivers. I have to turn the car on first, then turn the Tx on to get any of them to bind.
1 614 binds find 98% of the time, the second I have to have the Tx on the M1 profile to bind it then move it to the actual model that it's in. (The first 614 is on M1, I haven't checked to see if it will bind to another model.
Now the 603's one binds fine the other not at all, no matter what I try.
Is this is tx issue or issues with the rx's?
#114
On a different note, I've had my 4PKS-R for a little over a month now. What a dramatic improvement from my 3PM-X. Because the steering and throttle response is so much more smooth, my lap times have dropped dramatically, and more importantly lap to lap consistency has also dramatically improved.
#115
Seems like a lot of the questions in here don't get answered but here goes lol. The 2 dial above the grip first one being the steering dual rate, the second one the atl dial, is that a throttle dual rate? If so does that work with eclectic cars with esc's? As in you turn it down and it backs the braking power down, or does it slow down how fast the braking reaches full power? Thanks guys.
#116
604 vs 614 Receiver
Hello - I purchased a 4pk super R last week here. It was used 8 months with a receiver. I just noticed the receiver is a 604 receiver. I'm thinking the owner sold me the old receiver and kept the 614.
Does this make any difference in speed, etc. I race a SCT 410 Tekno. Any help is much appreciated. Thanks!
#117
#118
R603FF
R603FS
FrSky TRF4
But then again, the reason why I bought the 4PKS-R is for performance so I only use R614FS and R614FF-E in my cars.
I also run Spektrum DX4S on my off roaders (Spektrum has water resistant receivers). Works fine for me.
#119
Hi all
Is it possible change stock throttle trigger change to wider? Is it some tuning options?
#120
What I have done:
What I have done:
Pass you soon...
