KO Propo Electrical Switch 2 >
Old 05-05-2012 | 04:58 AM
favo's Avatar
Default KO Propo Electrical Switch 2
Hi Guy’s
Just wondering i have a KO Propo Electrical Switch 2.
What i would like to do is have a Y lead coming from the battery so that i can have a quick place to charge my battery.
Do you know if that is ok to do?
Will it damage the switch at all?
Or is there any way that i can do this?
Thank you for your help in advance.....
favo is offline
Old 05-05-2012 | 12:43 PM
RacerScott's Avatar
I would like to know this too. Getting ready to install mine
RacerScott is offline
Old 08-17-2012 | 03:10 AM
any bad/good exsperience with this switch?
i might by one today..
xray808-11 is offline
Old 08-17-2012 | 08:54 AM
The KO electrical switches are nice but their downside is being digital, they constantly drain the battery. Leads to dead receiver packs if you forget to unplug the pack at the end of the day. When I ran nitro, I preferred a normal mechanical switch with a rubber boot.
kcobra is offline
Old 08-17-2012 | 09:06 AM
thanks for reply.
i think i wil only put the conectors outside the box.
Old 08-17-2012 | 09:08 AM
Integra's Avatar
When running Lipo your Still forced to Unplug at the end of the day regardless. So i see that as being a Super small issue. Ill run a E Switch over a Mechanical switch ANY day of the week.
Integra is offline
Old 08-17-2012 | 04:56 PM
yes,its not a problem.But until now all my wires was in the box(xray xb9)
i need to take of 2 screws to get to the wires.Was thinking the ko propo switch was the way to go.And if i wil use that switch i need to make a hole or two in the box to connect the switch.But i just leave the connectors on the outside.Easy to connect/disconnect.
Did leave the store with a round of tires and pluggs instead
Old 08-17-2012 | 06:48 PM
Why?
kcobra is offline
Old 08-18-2012 | 12:45 PM
Integra's Avatar
Originally Posted by kcobra
Why?
LiPo batteries, no matter what, are always "running". Even when they're not plugged in to anything. The chemicals inside the battery are extremely volatile. If you happen to leave your LiPo battery plugged into an ESC, Receiver or Switch the battery is still connected to a current creating a continuous circuit. This makes the battery run even while you're not playing with it. Resulting in an Even Faster Self Discharge Rate lipo's Tent to be known For.
Integra is offline
Old 08-18-2012 | 08:56 PM
Incorrect. A battery (doesn't matter the type) will not be in a closed circuit if the mechanical switch is in the off position. Thus the reason it is "mechanical".
kcobra is offline
Old 08-19-2012 | 05:59 AM
+1
Old 08-19-2012 | 06:13 PM
Integra's Avatar
There's no Point in Arguing this, The Facts are out there for ANY one to look up.
Leaving Lipo's Plugged into Anything be it a Starter Box, ESC or Receiver. Its NOT recommended.
Integra is offline
Old 08-19-2012 | 06:27 PM
No point in arguing but no point in spreading mis-information either. Now I do agree that it is a good recommendation to unplug lipos at the end of the day even if a mechanical switch is part of the circuit. That switch could always accidentally get turned on.
kcobra is offline
Old 11-19-2012 | 04:10 PM
ekt's Avatar
ekt
I know this is an older thread, but the question in the first post hasn't been answered. Is there any chance of the switch being damaged running a y adapter from the battery to charge?
ekt is offline
Old 07-09-2015 | 04:21 AM
bump!!!
boomtheroom is offline
