UBEC help
Old 04-24-2012 | 09:05 PM
Default UBEC help
i am going to be running unregulated 2s lipo on my steering servo and regulated on my thorttle. i am getting a hobbywing ubec off of ebay and it has one side to plug into the reciever and the other end needs something sodered on to it. do i just soder it directly to the servo or what? http://www.ebay.com/itm/Hobbywing-5V...ht_1023wt_1037
The8ight is offline
Old 04-24-2012 | 09:44 PM
Other end gets connected to your battery
You will need to make an adapter to feed the lipo voltage to the servo as well
Signal wire will need to be fed between receiver and steering servo
Cheers
crusey_aus is offline
Old 04-25-2012 | 04:52 AM
So do I have to solder the other end so I can connect it to the reciever? And I just want to regulate one servo. I'm confused
The8ight is offline
Old 04-25-2012 | 05:13 AM
Loose wires on the UBEC will get connected to your battery (soldered or via a connector)
Servo type lead from the UBEC will connect into your receiver spare port and provide 6v to your receiver and throttle servo (regulated)
Then you will need to connect your battery (soldered or via a connector) directly to your steering servo for the unregulated supply
You will also need to run the signal wire from the receiver to the unregulated servo
A couple of servo 'y' leads will make it fairly simple
Cheers
Old 04-25-2012 | 07:31 AM
http://losi.com/Products/Features.aspx?ProdId=LOSB9608 Can I just get this regulator and get a y harness and plug that into my battery then plug the regulator in one of the plugs from the y harness then plug that regulator into my reciever then directly plug in the servo wire that I want unregulated into the other outlet on the y harness? So I would have to do any soldering? Thanks
The8ight is offline
Old 04-25-2012 | 05:07 PM
If you go to a hobby shop they will sell you what you need.You can squeeze on a end ,no soldering required or you can buy the wire and end.Cut the new wire and solder it to the BEC wire which will have the end plug you want.
http://www.hobbyking.com/hobbyking/s...idCategory=376
Cruze is offline
