Paralel charging
Old 04-16-2012 | 02:27 AM
Default Paralel charging
So I would like some info on paralel charging, if I got a traxxas y lead for my batteries would it be possible to charge 2 batteries at the same time. If one battery had less power would it only charge upto the same as the other battery ( when I say power I dont mean different mah level as my batteries are all 3000). would I have to have certain type of charger. Any info would be a great help. Cheers guys.
Tribeshead is offline
Old 04-16-2012 | 03:27 AM
Cell count needs to be the same size (capacity in mah) does not matter
Packs need to be at the same state of discharge (voltage) when you connect them
You need a parallel charge lead for the main lead on your batteries and also a parallel balance lead (or paraboard charging board)
Get the leads / boards from here
http://www.progressiverc.com/adapter...arallel-cables
http://www.progressiverc.com/adapter...-charge-boards
Cheers
crusey_aus is offline
Old 04-16-2012 | 03:30 AM
Ok so thats a no to just using parallel y cable. Thanks for the help.
Old 04-16-2012 | 03:42 AM
Parallel 'y' cable will be fine for the main discharge leads
You still need to parallel the balance leads though
Cheers
Old 04-16-2012 | 04:32 AM
Are your batteries lipo or nimh? Don't try to parallel charge nimh (or nicad), it won't work very well.
If lipo it just requires a charger with sufficient power and amps for best results.
Dave H is offline
Old 04-16-2012 | 06:02 AM
Oh mine are nimh. Cheers
Old 04-16-2012 | 06:37 AM
Sorry mate assumed you were talking about lipos
Nimh packs should not be charged in parallel
Cheers
Old 04-16-2012 | 06:40 AM
Alright thanks guys. Whatch this space for the next stupid question.
