Airtronics MT4 Drop Down By GridRC >
Like Tree4Likes
Old 03-15-2013 | 07:24 PM
  #241
Team Grid RC's Avatar
Folks,
Just helped bilster44 out with his steering wheel question.
The gap between the wheel and the clamshell is supposed to be about 1 to 1.5mm, but some wheels are thinner and placing the wheel almost against the shell. Also the wheel foam may be thicker than the wheel as well.
Quick solution is to use one or two fiber/phenolic washer from a brushed motor on the wheel control shaft, before screwing down the steering wheel. Each washer is 0.5mm thick, so no more than two is needed.
Ron
Team GRID
Attached Thumbnails Airtronics MT4 Drop Down By GridRC-brushed-motor-phenolic-washer.jpg
Team Grid RC is offline
Old 03-15-2013 | 07:40 PM
  #242
bilster44's Avatar
I had no trouble installing this crown jewel for transmitters...but the actual "depth" of some of the steering wheels can vary. So the very nice person (Ron) at GRID called me and told me that the wheel obviously had to be spaced out a little bit on the shaft. He mentioned that the phenolic spacer washers on the old brushed stock motors will work the very best...and they sure do too. With my wheel I used two of them. Now the steering wheel is perfect and away from the clam shell face as it is supposed to be. Her is a pic, and I will send a couple more a little bit later on.
bilster44 is offline
Old 03-15-2013 | 08:43 PM
  #243
Thanks Grid! The drop down is awesome wouldn't have expected such a nice light add on! Well done!
jake alton is offline
Old 03-16-2013 | 12:40 AM
  #244
madblu2's Avatar
To cure my rubbing problem I Dremel off .5 of the foam on the wheel and worked like a charm. Action feels smooth. Pics tomorrow. Ron you guys did a great job with it!!!! I will be racing with it tomorrow.
madblu2 is offline
Old 03-16-2013 | 02:08 AM
  #245
CarlCrocco's Avatar
here we go.
CarlCrocco is offline
Old 03-16-2013 | 08:06 AM
  #246
When I first installed mine the wheel foam rubbed so I just slid it out on the wheel, piece of cake.
Tijuana_Taxi is offline
Old 03-16-2013 | 05:15 PM
  #247
HollywoodRC's Avatar
Red face
I just got mine and my Radio has an after market aluminum steering wheel that is one piece. So there is no wheel travel adjustment guid and the shaft from the radio is to small to fit. Any body know where I can buy a replacement steering wheel and adjustment plate. Or any other solutions?
HollywoodRC is offline
Old 03-17-2013 | 06:48 PM
  #248
The drop down worked flawless today! I'm real happy with it!
Old 03-18-2013 | 08:16 AM
  #249
madblu2's Avatar
I love the drop down!!! It felt better in my hand racing this weekend. Great job Grid RC!!!
madblu2 is offline
Old 03-18-2013 | 08:19 AM
  #250
manu31's Avatar
I've received mine in France, I've mounted it, I tried it, it's perfect !!!! Sorry I can not post pictures (not enough post to use html links...)
Thank you
manu31 is offline
Old 03-19-2013 | 06:20 AM
  #251
Default Thanks to all!
Many thanks to all customers that supported the MT4 drop down project. It started off a year ago from a member request, but lack of interested got put off, and second time around same. But the third time, the interest was definitely there but for those that take the MT4 as a serious race radio that lacked a drop down.
We made sure that the drop down looked at home when mounted on the MT4 but yet still easy to install and provided performance being fully responsive.
Looking forward to your pics...
Ron
Team GRID
Old 03-19-2013 | 09:09 AM
  #252
bilster44's Avatar
Here's my plain Jane with no wrap yet...Man this unit sure does drive nice though , with no lag at all.
Attached Thumbnails Airtronics MT4 Drop Down By GridRC-20130316_201850_resized.jpg   Airtronics MT4 Drop Down By GridRC-20130316_201906_resized.jpg
Old 03-20-2013 | 02:36 AM
  #253
Carlos69's Avatar
Having trouble uploading a pic from my cell ... Anyway very happy .. Thanks Ron, team Grid and everyone else in on the 1st batch for making it finally happen !
Carlos69 is offline
Old 03-25-2013 | 07:40 AM
  #254
nanoverse's Avatar
Very easy to install and the new ergonomics are great. I like the weight too.
The links inside rub just a little bit to notice. Put just a dab of grease inside, hopefully using it more will remove the small rubbing. Have to post pics later.
nanoverse is offline
Old 03-25-2013 | 07:35 PM
  #255
Good to hear you finally got the drop down.
As for grease, we don't recommend any. The links are held in tension to give you zero backlash and are semi floating for maximum sensitivity.
If you must use grease, test the grease with just the linkage on the shell. If the linkage does not fall off when inverted upside down, then the grease is too thick and you will have stiction and lose sensitivity.
