Problem with Venom V550 4200kv Combo
#16
I am having a similar issue with my 4200kv combo. Using a 2 cell lipo I just got and cutting out after barely a minute or so. Any advice? Curious to know the solution.
#17
I feel that I bought a really bad combo, that does not work!!! I'm pissed off with this... I was better if I bought any Novak or Castle combos...
#18
The worse is that the Venom guys just disapeared!!! They don't answer this thread and my emails anymore!
#19
Hey I had the same issue with my venom on a stampede and I figured out that the low voltage cutoff was set too high. Stupid mistake on my part but it's worth looking into.
#20
Hi Mario,
I just sent you a PM, and confirmed your email.
I'll be out of the country for the next week with no internet access during that time.
If your issue isn't solved, I'll make sure it does when I return.
--Paul Susbauer
Venom Group International
--Paul Susbauer
#22
I would double and triple check it. I know it sounds dumb but set it to like 6.0 because what you're describing is exactly what happened to me. Would fire up and run fine for about 30 seconds then shut off and have to restart. Ie the lvc is kicking in.
