Esc question
Old 04-06-2012, 02:10 PM
Default Esc question
Quick question: i accidentally plugged the negative wire into the positive plug on my battery (also positive wire into negative plug). When i turned on the car, my capacitor on my esc smoke a little bit. The battery then stopped working. However, i put a new battery and everything worked fine.
Do you think my esc is ok?
Eaglesrx is offline
Old 04-06-2012, 10:53 PM
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Probably but you may want to replace the esc cap to be on the safe side.
MarkA is offline
Old 04-07-2012, 03:58 AM
Do you think it would be bad to continue running my car?
Eaglesrx is offline
Old 04-07-2012, 12:17 PM
Moderator
MarkA's Avatar
Depends on the ESC, some work Ok w/o the cap, some risk damage without it. It's a cheap fix, probably available at your LHS so you wouldn't even have to order it.
MarkA is offline
