A newb type question?? >
Old 03-13-2012 | 11:18 PM
rcduder's Avatar
Default A newb type question??
haha this may be obvious what the answer is but does the amp output of an esc have an effect on speed? like i will use the hobbywing esc's for an example and they have two different stock spec esc's the justock: 45 amp and the extreme stock: 60 amp will the extreme stock be faster then the justock with both esc's being at zero boost and zero timing? like noticeably different speeds?
rcduder is offline
Old 03-13-2012 | 11:28 PM
Choice of motor determines your speed
Load on the motor (gearing, weight) determines how many amps are drawn from your battery, ESC simply provides a path
If you gear the car for more speed it will draw more amps
Cheers
crusey_aus is offline
Old 03-13-2012 | 11:33 PM
rcduder's Avatar
Cheers
ok cool thank you. so what is the 45 amp or 60 amp rating on the esc's then? so the 60 amp esc would be the same speed as the 45 amp esc if im running 17.5 no timing on both?
rcduder is offline
Old 03-13-2012 | 11:43 PM
Batteries have a continuous and burst amp rating
ESC's have a continuous and burst amp rating
Motor's have a continuous and burst amp rating
In an ideal world you want your ESC and Battery's continuous ratings to be greater than your motors burst rating
Example
100 amp burst motor
120 amp cont. ESC
150 amp cont. capable battery (5000mah 30c)
If you keep the same motor and simply change ESC's you are unlikely to notice any difference
Cheers
Old 03-14-2012 | 09:16 AM
rcduder's Avatar
Example
100 amp burst motor
120 amp cont. ESC
Cheers
cool thanks man
rcduder is offline
