help airtronics mx3x with sc10 >
Old 02-28-2012 | 06:53 PM
Mazinga's Avatar
Default help airtronics mx3x with sc10
Hi guys I'm new to the hobby and i need some help please. I just bought an mx3x radio and receiver and I want to put it in my sc10. I connected the esc (stock esc brushless )and servo and after I turned on everything I noticed the the esc takes a longer time to allow me to use the throttle than my original stock radio ,and also I cant stop the car to go in reverse. Besides this, the servo and the trottle work fine except that when I give "gas" and releive, the car doesnt stop but goes back in reverse .... like i said I'm new and I dont know much about this so if somebody can help, I appreciate it. Thanks
Mazinga is offline
Old 02-29-2012 | 06:57 AM
apriliamille's Avatar
stock esc? is this the rtr sc10? the only thing i could see is page 21 final adjustments section step 6.
http://www.teamassociated.com/cars_a...anuals_setups/
do you have any documents for your esc that allows you to set it's throttle neutral brake range to the new tx
sorry i cant give more info then that as i have never played with the rtr kit. but pretty much all esc whether its cars or air need their range set to the tx
apriliamille is offline
Old 02-29-2012 | 07:11 AM
if it is the stock sc10 esc look at this
http://www.teamassociated.com/pdf/ca...206%202011.pdf
go to throttle calibration section
Old 02-29-2012 | 01:24 PM
Mazinga's Avatar
Problem resolved thanks. I had to set the new radio with the Esc , i dont know Why i Was thinking / expeting that every radio as the same neutral point .
Mazinga is offline
