Any suggestions for logging?!
Hi there,
I just got a Tekin RX8 to put in to my Kyosho MP9 and was wondering if there is way to log the current draw so I can take a look at it later?! Not interested in looking at it while driving!
thanks,
G
thanks,
G
One option, but I understand it does not work with 64 bit computers. I got one I use with windows XP & 7, 32 bit.
http://www.teamnovak.com/products/da...try/index.html
Last edited by dtr; 02-15-2012 at 02:25 AM. Reason: Thanks for the reminder, url corrected.
http://eagletreesystems.com/Car/car.html
I got the novak because I could afford it. lol
Eagletree may be better, I don't know & they may have one less expensive. Also Novak has no plans for any more updates (software)
They (Novak) do not list a replacement mount ( It will eventually break) No biggie you just need to place tape over the usb port while running in a vehichle.
The prices I found novak $69 eagletree $149
Also not sure of warranty on novak
Just some pros & cons of both
Thanks for the input guys! I had Novak products before and liked them. I also checked the eagle tree stuff and it seems to be solid as well. Would this be something I am looking for?!
http://www.eagletreesystems.com/MicroPower/12.htm or sgould I get this one instead:
http://www.eagletreesystems.com/Car/car.html
How good is the accuracy on these things?! I am mainly interested in AMP draw?!
thanks,
G
thanks,
G
The one best for you would probably be the one that does what you are looking for. Any extras you might use in the future are a definite Plus.
Also make sure the one you choose can handle the amperage your system carries.
I have checked temp & amp draw with an ammeter (no load) Mine (a Novak) was within 1/100th of an amp.
I have no reason to believe anything from Eagletree could be less accurate. I have heard only good abouy their products.
Hope this helps
Hope this helps
thanks,
G
I have no reason to believe anything from Eagletree could be less accurate. I have heard only good about their products.
Hope this helps
Hope this helps
G
thanks,
G
G
