Transponder low voltage issue ??? >
Old 02-08-2012 | 04:21 AM
Parnelli's Avatar
Default Transponder low voltage issue ???
I live in Minnesota and run VTA with a 1s battery (don't ask). I have the Novak voltage booster for my ESC. My receiver is the Spektrum SR3300T. The problem is when I brake the the light in the transponder goes out. Adding a capacitor with a Y harness at the rec. port does not help. I used to run a 9 volt battery as booster pack and this took care of the issue.
I prefer to just use voltage booster and save some weight. What else can I do to solve the problem? Thanks, DP.
Parnelli is offline
Old 02-09-2012 | 04:58 PM
Default transponder
I have a house transponder thats been converted to a rec wire plugin for power. It was designed to run on 1.5v, and has a very strong signal at 6v, Kevin played around testing how strong it was. I would say that this would be a good option if you can find one. It doesn't miss a lap, even in a monster truck
btrukr is offline
Old 02-10-2012 | 04:01 AM
Parnelli's Avatar
Default Transponder voltage
Thanks BT, I may have to use a club unit from now on. My 2nd option is a new Mylaps unit at $120.00 shipped (ouch). They claim on the website to need just 2.8 volts for minimum power. DP
Parnelli is offline
Old 02-10-2012 | 04:32 AM
Makes for a little messier car, but something like this should power a transponder, and save a little dough:
Any Volt Micro
Dave H is offline
Old 02-10-2012 | 01:37 PM
TOM MAR's Avatar
And another option would be another booster from the battery leads to the booster to the transponder.
I got a couple of these.
http://www.hobbyking.com/hobbyking/s...idProduct=7884
But any booster should work.
LOL I run 1 cell 3.5 2 wd sct on occasion.
TOM MAR is offline
Old 02-11-2012 | 12:57 PM
Parnelli's Avatar
Default Low voltage for Transponder with 1S battery
I ordered one of these;
Novak 4 Cell Transponder Voltage Booster Module
Extended Product Information:
The module connects between the vehicle’s transponder and the receiver, and boosts voltage to the transponder for consistent lap counting—even when the battery pack is dumped.
Parnelli is offline
Old 02-11-2012 | 05:09 PM
TOM MAR's Avatar
I forgot they had that. Attachment 876948
TOM MAR is offline
