-   -   150C battery (https://www.rctech.net/forum/radio-electronics/592713-150c-battery.html)
TakeAim 01-28-2012 07:00 PM
150C battery
I'm a beginner and would like to run my Losi XXX-SCT in Stock and Mod classes. I was wondering about an interesting LiPo battery. I'm sure there are other brands, but MaxAmps has a:
Hard Case Race Edition LiPo 6500 2-cell 7.4v Battery Pack with a true 150C rating. Ignore the expensive price for now.
ROAR APPROVED
3-year 300-cycle guarantee
45+mph in most brushless setups(7.4 volts)
39 minutes average run time(6500mah capacity)
True 150C rating
5C fast charge capable
100% waterproof
Hard outer case
Built today with factory fresh cells
Built with genuine 12awg Deans Ultra wire
We add the connectors and balancing taps for you
139mm x 47mm x 25.1mm, 354g
Would not this battery give my stock SCT running a Tekin 17.5 turn motor and Tekin RS ESC great acceleration using blinky mode? Wouldn't it run more like a Mod class SCT? After successive quals, several quals, and maybe a main, it might warm up the motor and ESC, however. But it should run a long time.
I may not have time between the quals to adjust the ESC out of blinky into something else. There are two buttons on the Tekin ESC which can adjust things such as the throttle profiles from mild to aggressive. I can only guess that this may be the way to change from blinky to mod if there is enough time between quals.
But I don't understand the buttons and LEDs on the ESC and how to switch from blinky to whatever mod mode is best for Mod.
Maybe consider another battery company? But is this concept valid of using a large "C" battery?
TakeAim
Dave H 01-28-2012 07:24 PM
Some of the many threads discussing that battery. They even have some test data. Short answer is no, no, and no. Independent testing routinely indicates mediocre at best performance.
http://www.rctech.net/forum/electric...sive-crap.html
http://www.rctech.net/forum/electric...highlight=150C
Can't help with the Tekin, but the thread in the off road forum is generally pretty active, with Tekin reps. Might get a quicker response there.
http://www.rctech.net/forum/electric...s-offroad.html
