c ratings.
is there a good way to figure what c rating lipo i need for my set up before i buy more batts. i already have some 5200 mah lipo`s with a 50c rating but haven`t used them yet and am going to buy 3 more for my other car but wan`t to make sure i don`t buy more then i need or more importantly to little.
Your motor will have a burst amp rating
Your batteries continuous rating needs to be higher than it
Example
100 amp burst motor
5000mah 20c pack = 100 amps available and borderline
5000mah 30c pack = 150 amps available and a much better option
Cheers
Example
100 amp burst motor
Cheers
ok thanks i will check the motor ratings. i just looked at the novak spec chart and it dosen`t tell me the amp draw of the motor. its the 13.5 ballistic . do i need to do some math to figure the amp draw using the kv and watts ratings given in the specs.
