Soldering Iron
Old 01-13-2012 | 07:33 PM
IROC-AR15's Avatar
Default Soldering Iron
Is a 60 watt solder iron good for soldering my Tekin motor wires? Also any particular type solder I should use?
IROC-AR15 is offline
Old 01-13-2012 | 08:03 PM
I used a 40 watt iron on my Tekin ESC/Motor with no problems so it should be fine. Just make sure you coat the tip of the iron with solder and tin the wires and terminals that you are soldering to. A tip that helped me solder to the esc posts was to flatten the wire with pliers after tinning it. This way, it can more easily slot into the cutout on the solder post.
mushroomed is offline
Old 01-13-2012 | 08:12 PM
IROC-AR15's Avatar
Thanks Man...I appreciate it!
Just got a sweet deal on a 3 brand new 60 watts irons!
Old 01-14-2012 | 05:47 AM
yes a 60 watt will work i use a 90w i also use 60/40 solder for electronics
jmc33194 is offline
