Savox and Spektrum issues
I am beginning to think that my glitch issues are related to my savox high voltage servos I am using for throttle. I've read about using a glitch buster, but my thoughts is I am running an unregulated lipo pack, so that should be plenty of voltage and amps for the servo right?? My rx box is tight enough with out cramming a capacitor in there... has any one else had this issue??
Recently my friend was having issues with his RC8Be. He has a Savox steering servo and a Spektrum reviever. Without using a glitchbuster his car was undriveable, kept loosing the reciever signal. With the glitchbuster it works perfect.
E
E
me and my buddy both run savox and spektrum together and have never had a problem. i do not have the HV servos though. did you try a diff servo, receiver or switch. I had a problem my switch I guess was going bad and caused my throttle servo to go crazy sometimes.
Savox servos are very demanding on power. You need to put a cap/ glitch buster on your rx. It will eliminate you problem.
What is happening, is when your servo is used it sucks the power from the Rx at suck a high rate it will lose its bind to the Tx for a fraction of a second causing you glitch. Its not enough to completly shut the system down, but it will play havoc with you.
Get one of the Spektrum one for like 5 bucks and plug it into an emtey slot on your Rx. If you dont have an empty slot, you will need to solder it in. I would recomend putting it on the switch harness that plugs into your Rx. Dont put it on the battery or before the switch as it can charge up and zap you. Also dont put it on a servo wire. Hope you get it working.
