Software Problem with Hitec Servo Programmer HPP21 >
Old 01-06-2012 | 08:05 AM
Tarimon's Avatar
Default Software Problem with Hitec Servo Programmer HPP21
Hello,
I have bought the Hitec Servo Programmer HPP21, but its impossible to start the PC-Software, it aborts with error message. For more information please see the red marked message in the desktop-Screenshot of the following link:
http://tarimon.lima-city.de/manuals/...21_problem.jpg
Someone else the same problem?
I would be glad if someone of you is able to help me.
Tarimon is offline
Old 01-06-2012 | 06:21 PM
Re-Register the file:
You can Re-register this file it by typing "regsvr32 comdlg32.ocx" from the command line in the system32 directory.
Perform the following steps to make the changes:
1. Click Start
2. In the Search bar type CMD
3. In the programs pane right click on cmd and "run as an Administrator"
4. Put in your credentials for UAC prompt
5. In the command prompt type in "regsvr32 comdlg32.ocx" then press ENTER
Also you can try downloading http://windowsxp.mvps.org/utils/Comdlg32.zip and putting it in the same directory as the HPP21 program
Linkdead is offline
Old 01-07-2012 | 12:52 AM
Tarimon's Avatar
1. Click Start
Hi Linkdead,
thank you for your answer, iīve tried both, but nothing changes. Iīve copied the downloaded ".ocx" file to c:\windows/system32 directory also, try to register it again, restarted the computer and tried your tip again, but I only got a new error message, which said the following:
The module "comdlg32.ocx" is loaded, the call to 'DllRegisterServer' is failed with error code 0x8008021c
http://tarimon.lima-city.de/manuals/...1_problem2.jpg
Any ideas on this?
Tarimon is offline
Old 01-07-2012 | 08:09 AM
Sounds like you registered the file as a user and not an administrator. Do all the steps again logged in on the administrator account. Additionally have you tried to run HPP21 as the administrator or in windows XP compatibility mode (troubleshoot compatibility)?
C:\Windows\SysWOW64 is where you should copy comdlg32.ocx.
Linkdead is offline
Old 01-07-2012 | 09:23 AM
Tarimon's Avatar
First, thank you for trying to help me...!
Sorry, but I donīt have a folder "sysWOW64" on my sytem. Eventually it is because I donīt run the 64bit Version of Win7...?!
Additionally I also donīt have any other account as my admin account...
Tarimon is offline
Old 01-07-2012 | 09:38 AM
Tarimon's Avatar
Okay, I found my fault.
Although I was already logged in as Administrator, I still had to select "run as administrator" when starting "cmd.exe". I didnīt know I had to do it that way...
Thankīs for your help again!
Tarimon is offline
