Limiting kV
#33
On the rc-monster forum Patrick has said that torque control is not a direct current limiter, but controls torque directly, and in another post that they're working towards traction control, so I guess it is based on measuring phase delay of the motor.
#35
#36
The most likely way to implement traction control would be to limit the rate at which the motor is allowed to accelerate. This would be rather simple to implement in software, but the calibration of it for a given setup (motor/voltage/gearing/tire size) would be pretty tricky for the average hobbyist.
#37
Crusey, could you contact Castle?
That statement makes absolutely no sense. In an "ideal" electric motor, torque is directly proportional to current, and so controlling output torque is accomplished by controlling the winding current. There are a lot of other variables that factor into this, but that's the general concept.
#39
Didn't think this would be so controversial.
I ordered some spur gears and some pinion gears and I'm going to play around with the ratios.
Thank you so much to all of you for so much information that my brain is still comprehending.
#40
Look up Patrick's comments in this thread, especially post #38.
Note that the end result is the same - the winding current is limited in order to limit torque.
I mean measuring how far off the motor is from its ideal no-load position the more the difference, the higher torque it is forced on.
