Dx3r antenna replacement
did you take the dx3r sticker off the top? Just asking. I had mine apart a while back to replace the antenna and install a back light kit. Just off the top of my head the sticker. The three screws that hold the wheel to back plate. The screen has a clear plastic protector with spektrum on the boarder, That has to come of. Its tacky so you can put it back on, just lift from a corner.
Yeah, had the same 'issue' you are running into. The screen/cover is glued in place. Be careful and work slowly and you can work it off. Once it's off everything will come apart just like you'd expect. The glue is very good because it went right back together without issues.
