Spectrum RX woes
Has anyone experienced any faulty SR3300T rx's? I've had three so far go dead or won't bind after use.
The first one worked fine for three weeks, but when I got home and started to make some adjustments, I turned the rx on and there was response from the car. I tried to rebind and the rx would just continue to flash fast and not bind.
I sent that one back to Amain hobbies and that one worked for two weeks. I sent that back, got another and after about 45 minutes of use I packed up and went home. I get home and unpack and the new rx won't bind. I'm getting very frustrated with this. I am running an unregulated LiPo, but the rx is supposed to handle 12 volts and I am using high volt servos.
Is this Spectrum Voltage Protector
http://www.amainhobbies.com/product_...tage-Protector
something that would help? And why?
Thank You
Brian
Thank You
Brian
Glitch buster style cap wont help if you are having bind issues
Its used to help with bec related (high servo load) problems
What ESC are you using ?
Does the receiver brownout (lose connectivity) when you load up the servo ?
Cheers
Cheers
Sorry Guys, I should have said that it's a nitro car. I'm not sure that it is a bind issue. They seem to be fine while I'm running, it's just after I get home, I get no response from the car, so I try to re-bind and just get the fast flash.
I have done nothing but put it in the bag bring it home and I've run into this three times now. I'm thinking I want another brand of radio!
I was thinking that maybe the high volt servo's are drawing to much current for the rx (even tho it's rated at 9.6 volts, I'm not sure about amps)and that the Spectrum Voltage Protector might help. For the price I think it's worth a try.
Amain said if this one fails, I have to deal with Horizon. I don't want to wait for them to deal with this.
I've spent soooo much money already, I know it's the nature of the hobby, but I can't spend for another radio for a while.
Doesn't sound like anyone else has had similar problems. I thought I saw a post about Spectrum rx and Savox servos pulling to much power. The funny thing is that the last time it happened I was using a Hi-tech servo for steering. I don't see any brown out problems, they work fine when I'm running that day.
I'm really at a loss about what to try next!
Brian
Brian
Brian
Brian
Brian
Heck yeah. Those Savox servos are real power hogs. I have three of them and put the Spektrum cap on each receiver which solved the problem. I first noticed this running 2wd buggy mod and whenever I was exiting a turn I would lose power, it was from the servo pulling high amps causing the receiver to brown out. I put in the cap and haven't had a problem yet.
Cheers
Brian
We've had similar issues at our local track. The servos are drawing too much for some of the speky recievers. We think its because the spektrum recievers need a higher operating voltage or current and the servos cause too much of a power drop. The same servos plugged into a futaba system does not cause the issues.
Adding a cap 99% of the time eliminates the issue.
I have been running Spek receivers with Savox (Orion) servos for almost two years (in nitro cars) and not had those issues. I have run Spektrum radios and receivers for about 4 years, but not with the Orion servos. Prior to the Orion servos I have used every Spek receiver except the SR3100 and 3300. I have run Nimh, Lipo (regulated) and now Life (unregulated). Since going to the Orion servos the only receiver I have used is the SR3520 receiver.
Brian
Brian
OK, I ordered the caps, but they won't be here before the weekend racing.
And I don't want to take a chance on burning out any more rx's.
So, I'm gonna check the electronics store tomorrow for some 4700 microfarad caps and make my own for the weekend.
Cheers
Brian
Cheers
Brian
