revtech help!
Old 11-06-2011 | 06:44 PM
twotoxic's Avatar
Default revtech help!
i just got this revtech motor that got burnt up and i dont know what happened but was wondering how to fix it, the stator has solder coming out the side of a hole just wondering if i could replace the stator ? or if i could replace it with a d3 stator?
twotoxic is offline
Old 11-06-2011 | 07:00 PM
For_the_win's Avatar
Did you run it with boost? I herd they dont do well on boost. But i think you have to get the same strator that is in the it now to replace.
For_the_win is offline
Old 11-06-2011 | 07:19 PM
twotoxic's Avatar
do you know were i can get a replacement stator its a 13.5 thanks
twotoxic is offline
Old 11-07-2011 | 03:26 PM
twotoxic's Avatar
Anyone know were to get the sator?
twotoxic is offline
Old 11-07-2011 | 04:34 PM
trerc's Avatar
Here ya go
http://www.fantomracing.com/proddeta...rod=FAN28313_1
trerc is offline
Old 11-08-2011 | 05:36 AM
twotoxic's Avatar
Thanks but I need the revtech stator
twotoxic is offline
Old 11-08-2011 | 06:30 AM
ovalracer1m's Avatar
http://www.trinityrc.net/shop/index....mation/contact
Calling them directly would be your best bet. You must have got that motor wayyyy to hot if there is solder coming out the can No other way that could happen besides extreme heat. When a motor gets that hot, the rotor is weekened as well (looses its magnetism). Probably better off turning that motor into a paper wieght and repacing it instead of spending $40 on a rotor and still having a motor that is not running at its full potential.
Keep an eye on temps, expecially with a new motor. Never above 160F. Get yourself a little mini tempgun. Can be had for $20 or so.
ovalracer1m is offline
Old 11-08-2011 | 10:16 AM
twotoxic's Avatar
We actually got this motor from someone, was hoping it might be salvageable but it doesn't look that way thanks for the info. It was still hot when we pulled it out and it had been awhile since he ran it.
twotoxic is offline
Old 11-08-2011 | 05:55 PM
The melting point of alum is 1220F......you got it hot alright.....!
Duster_360 is offline
Old 11-08-2011 | 07:35 PM
twotoxic's Avatar
the guy we got it from had the timing negative on it
twotoxic is offline
