Receiver Battery
Thinking of buying one of these,would like to know what other users think of the life
A123 6.6V 2300mAh 2s1P LifePO4 Receiver Battery
The OlevinPower OP-2300RX J Receiver Pack uses genuine Enerland Lithium Ion~A123 Cells. A perfect receiver pack that will provide plenty of power and hours of flying.
Spec:
Capacity: 2300mAh
Voltage: 6.6v
Constant discharge: 6-10C
Max Charge Rate: 4C
Weight: 161g
Discharge Plug: JR
Comes with 21cm discharge wire
Spec:
Capacity: 2300mAh
Voltage: 6.6v
Max Charge Rate: 4C
Weight: 161g
Discharge Plug: JR
There are two types of lifes available - original life by a123 (which they patented) and the newer ones I see referred to as 'prismatic' type life that are apparently not patented since so many seem to be making them.
I use the 2300mah type a123s as a power source for running some of my rcs where I have room for them. That's the main drawback to the a123 type - their size and weight. They seem to take a lot of abuse and not really care. The prismatics are lighter and smaller in size, but seem more sensitive as far as charging at least. Many brands recommend breaking them in and they have a rep for puffing without a lot of warning from what I've read. I have a 2100mah 2S Hobbico prismatic type life I use as a rcvr batt though and its been trouble free so far.
I use a 3PK (and 3PJS) radio and both are run with a 3000mah 3S lipo. Amain sells lipos that will fit the 3PK radio. I wouldn't go back to batteries, charge lasts much longer and teh radio weighs noticeably less.
