Running in reverse
I have a HB Ve8 running a Tekin T8 1700kV/4S 14.4v battery / Rx8 BL ESC/ Spektrum SR300 Rec. and a DX3C radio. With everything hooked up , I found that everything is running in reverse.
Fast reverse speed (forward throttle)
Slow foward speed (rev. throttle)
Steering reversed.
Is this a radio issue or an ESC issue?
Steering reversed.
Sounds like a radio issue. You should be able to change settings on your radio. My son and I both have the same car, esc, motor, and steering servo.
I run a Futaba 4pk, and he runs an m11. Right out of the box he had to reverse his steering servo and I had to reverse my throttle.
