tekin pro or castle? >
Old 10-11-2011 | 06:01 PM
Doitinthedirt's Avatar
Questions?? tekin pro or castle?
Getting serious again about rc racing after 10 years off...all I hear about is "tekin" and "castle"..what are the pro's and cons of both? ....Any feedback would help thanks
Doitinthedirt is offline
Old 10-11-2011 | 06:33 PM
Too broad of a question
What car ?
What voltage ?
What motor ?
What speed ?
Cheers
crusey_aus is offline
Old 10-11-2011 | 09:55 PM
What car ?
What voltage ?
What motor ?
What speed ?
Cheers
Just looking for feedback..I didn't know I had to amuse people..lol
Let's say sc10,17.5 class
Old 10-11-2011 | 10:35 PM
Mxer59's Avatar
I've ran Tekin and Castle, nice thing about Tekin is there sensored castle only the Esc's mamba max pro. But I had a lot of technical issues with Tekin there both good brands. Right now I've gone over to Novak
Mxer59 is offline
Old 10-12-2011 | 12:56 AM
So sensored does make a difference? ....I use to run with novak back in the days I never had a problem then....but now some local track guy's say "stay away from novak" so i don't know...lol also what's up with this boost thing in the motors? Any or all info would help...thanks guys
Old 10-12-2011 | 06:58 AM
Mxer59's Avatar
Sensored Suppose to be smoother and no cogging issues. Boost is just like a timing advance makes everything run a little faster.
Ive heard bad things on Novak but want to give them a shot
Mxer59 is offline
Old 10-12-2011 | 10:52 AM
Thanks for the help/information
Old 10-12-2011 | 11:06 AM
I say traxxas. I have used LRP,NOVAK,Tekin in my SC and found I get longer run times and cooler running with VXL- 3S ESC.
http://www.google.com/products/catal...ed=0CD8Q8gIwAA
Tim3 is offline
Old 10-12-2011 | 12:23 PM
..I completely forgot about traxxas...I need to do some research on it ...thanks
Old 10-13-2011 | 02:47 PM
BAD007SUZUKI's Avatar
Default NOT TEKIN
I HAVE A TEKIN RS AND RS PRO. BOTH WERE PURCHASED BRAND NEW. INTALLED THE RS PRO IN A SERPENT S411 SEDAN. THE PRO CRAPPED OUT FIRST. SO I SWITCHED IT TO THE REGULAR RS. BOTH DID THE SAME EXACT THING. I ALSO SWITCHED MOTORS AND SENSOR WIRES. (I'VE BEEN IN R/C FOR 15 YEARS SRAIGHT) BUT ANYWAY, ITS LIKE THEY WERE RUNNING SENSOR LESS. I SENT BOTH UNITS INTO TEKIN, AND THEY SENT BRAND NEW ONES BACK. SO I INSTALLED THE RS PRO BACK IN MY TOURING CAR, USED IT FOR ONE WEEK, WON THE MAIN THAT WEEK SINCE ITS ONLY THE SECOND RACE OF THE INDOOR SEASON, AND YESTERDAY IN PRACTICE IT BLIPPED ON THE STRIGHT AWAY, AND STARTED DOING THE SAME THING.
IM NOT DOING ANYTHING OUT OF THE NORM, AGAIN....IM NOT NEW AT THIS. NORMAL TIMING AND GEARING, INDOOR ON CARPET WITH A TOURING CAR. SO I SENT A REALLLLLLY CRAPPY MESSAGE TO TEKIN.
I INSTALLED THE RS INPLACE OF THE RS PRO AND CHECKED THE MOTOR ON A HITECH MOTOR CHECKER, MOTOR IS NOT THE ISSUE. AND CAR WAS RUNNING FINE AGAIN. (SAME SENSOR WIRE) SENSOR WIRE IS NOT THE ISSUE EITHER))
IM STAYING AWAY FROM BUYING ANYMORE TEKIN. WHEN YOU SEND YOUR STUFF IN, YOU HAVE NO IDEA WHAT THEY WILL CHARGE YOU "BECAUSE THEY HANDLE TOO MANY ISSUE ON A DAY TO DAY BASIS" . THE FORM YOU SEND IN REQUIRES YOU TO PUT YOUR CARD INFO ON IT SO THEY CAN JUST CHARGE YOU WHATEVER. WHATS THAT TELL YA?
MAYBE THIS HELPS.
IM GOING TO SEND MY DAMAGED UNIT IN, AND SWITCH TO SPEED PASSION OR LRP. (IF I CAN GET SPEED PASSION) LOOKS LIKE THEY ARE COMING OUT WITH A UPDATE TO THE GT2.
BAD007SUZUKI is offline
Old 10-13-2011 | 03:20 PM
MAYBE THIS HELPS.
..wow that's scarrry to know I'm really thinking of getting the tekin rs pro because of the hotwire software...also I know castle makes the castlelink software also so idk.... but I never really hear anything negative about the tekin system at my local track it looks like 90% of the people run the rs pro....and never say anything negative so it looks like more Google search for me...lol.
Old 10-13-2011 | 03:29 PM
samnelso's Avatar
You don't need a RS Pro for a 17.5 You can save some $, size, and weight by going with a regular RS.
samnelso is offline
Old 10-13-2011 | 03:36 PM
....very true but at the same time i want a ESC that don't have a limit just incase i want to drop a bigger motor in
Old 10-13-2011 | 04:28 PM
For_the_win's Avatar
I think hes doing something wrong
For_the_win is offline
Old 10-16-2011 | 09:35 PM
Update.....I just installed a tekin rs pro with a 17.5 in a factory team sc10 and all I have to to say is WOW! This is my first sensored motor/setup...after doing a hotwire tune thanks to a friend at a local track this thing rocks its stupid fast so let's see how it works out.....so far so good
